ASUS SBW-06D2X-U
zittrig
Re: ASUS SBW-06D2X-U
#136 Post by zittrig » Wed Feb 19, 2025 6:11 am
Recovery flash from 16D1HT to BU40N 1.03MK I've wrote. Means the 1.03MK is the final firmware because the BU40N is the drive in this ASUS enclosure.
Check 4k with the 1.03MK.
revere
#137 Post by revere » Wed Feb 19, 2025 4:18 pm
Yes, please send next PM. Thank you!
Coopervid wrote: Sun Feb 16, 2025 6:09 pm
PM sent.
Antihero
#138 Post by Antihero » Fri Feb 21, 2025 12:50 pm
Can someone help me make my drive UHD compatible?
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ...
Firmware date: 2023-04-20
Firmware version: ID26
#139 Post by d00zah » Fri Feb 21, 2025 2:34 pm
Antihero wrote: Fri Feb 21, 2025 12:50 pm Can someone help me make my drive UHD compatible?
Manufacturer: ASUS
Revision: E102
Serial number: ...
Regrettably, thanks to Pioneer, that can't happen (to date?).
suivulP
#140 Post by suivulP » Tue Feb 25, 2025 3:38 pm
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ...
Firmware date: 2017-04-18
Firmware version: ID22
Seems to be LibreDrive compatible & old enough firmware. Thanks for any assistance on the correct firmware to use.
#141 Post by Coopervid » Tue Feb 25, 2025 7:52 pm
suivulP wrote: Tue Feb 25, 2025 3:38 pm Drive Information
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
Dademurph74
#142 Post by Dademurph74 » Thu Mar 06, 2025 2:51 am
Just picked this drive up in hopes that it can do UHD. I have 2 others that are too old.
I hope it's possible haven't seen any with this particular Firmware Date:
OS device name: J:
Manufacturer: ASUS
Revision: A102
Serial number: ***********
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 47
#143 Post by Coopervid » Thu Mar 06, 2025 9:22 am
Dademurph74 wrote: Thu Mar 06, 2025 2:51 am Just picked this drive up in hopes that it can do UHD. I have 2 others that are too old.
OS device name: J:
Manufacturer: ASUS
Revision: A102
This is a LG drive and needs to be flashed with LG firmware. See post on previous page by NotitaPls and zittrig's answer.
dsr566
#144 Post by dsr566 » Fri Mar 07, 2025 11:39 pm
Hi Coopervid, keen to upgrade this drive to libredrive firmware. Thanks in advance.
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.10
Serial number:
Highest AACS version: 66
Drive platform: RS8591
Firmware version: 1.10/ID22
#145 Post by Coopervid » Mon Mar 10, 2025 8:19 pm
dsr566 wrote: Fri Mar 07, 2025 11:39 pm Hi Coopervid, keen to upgrade this drive to libredrive firmware. Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
Serial number:
PM sent.
lbr5539
#146 Post by lbr5539 » Sat Mar 15, 2025 4:45 pm
Hello. For Cooper that seems to help a lot of people, could you DM me as well with the Libredrive info? Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
Serial number: ---
Highest AACS version: 81
#147 Post by Coopervid » Sat Mar 15, 2025 7:28 pm
lbr5539 wrote: Sat Mar 15, 2025 4:45 pm Hello. For Cooper that seems to help a lot of people, could you DM me as well with the Libredrive info? Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
Serial number: ---
PM sent.
Axelbcn
#148 Post by Axelbcn » Sun Mar 16, 2025 7:03 pm
Hi! Can someone help me to flash my drive to Libredrive friendly firmware? Thanks in advance!
This is the makemkv info:
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
#149 Post by Coopervid » Sun Mar 16, 2025 8:29 pm
Axelbcn wrote: Sun Mar 16, 2025 7:03 pm Hi! Can someone help me to flash my drive to Libredrive friendly firmware? Thanks in advance!
OS device name: H:
Manufacturer: ASUS
Revision: 1.10
Serial number: ...
PM sent.
Axelbcn
#150 Post by Axelbcn » Sun Mar 16, 2025 9:03 pm
PM sent.
It has worked as expected.
Small donation sent. Thank you very much.
