Heretic - UK UHD - Dump Submitted
Monkeylord
#1 Post by Monkeylord » Tue Feb 25, 2025 12:02 pm
Dump submitted for UK version of Heretic
MKB20_v77_Heretic_8A30
keydb_helper
Re: Heretic - UK UHD - Dump Submitted
#2 Post by keydb_helper » Tue Feb 25, 2025 1:49 pm
The 8A30 variant of Heretic has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
Monkeylord
#3 Post by Monkeylord » Tue Feb 25, 2025 1:59 pm
I did update my KEYDB after it failed to open the first time, but it didn't work (hence the post).
Just finished tinkering with a little issue I had with the car and have updated my KEYDB again. It's working lovely and is ripping the encrypted backup I made as we speak.
Thanks for your efforts!
