ASUS BW-16D1X-U - Flashable?
husked
Re: ASUS BW-16D1X-U - Flashable?
#91 Post by husked » Sun Feb 16, 2025 10:22 pm
Coopervid wrote: Sun Feb 16, 2025 6:18 pm
husked wrote: Sat Feb 15, 2025 8:30 am Which means? I was not able to find the exact same circumstances in other postings, everything else works out fine and the software is doing its job perfectly, which is a reason to be happy :)
PM sent.
Yes, please send next PM
tekmo
#92 Post by tekmo » Tue Feb 18, 2025 6:29 pm
Hi I purchased said drive (BW-16D1X-U) and wondering if it can be flashed for UHD.
Here is the info:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: ---------------
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
zittrig
#93 Post by zittrig » Tue Feb 18, 2025 8:38 pm
Try flashing to BW-16D1H-U A204, which you can find in the MK Firmware Pack in the first post here ... viewtopic.php?f=16&t=19634
The Flasher 1.3.5 you can find there also.
jinx100
#94 Post by jinx100 » Tue Feb 18, 2025 10:25 pm
tekmo wrote: Tue Feb 18, 2025 6:29 pm Hi I purchased said drive (BW-16D1X-U) and wondering if it can be flashed for UHD.
Here is the info:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
As @zittrig said, use Marty McNuts SDFtool Flasher viewtopic.php?f=16&t=22896 . Marty's "All You Need Firmware Pack" is found on the same page is smaller and simpler (maybe shorten the folder name to "AYNFP". Choose "DE_ASUS_BW-16D1HT_3.10_MK.bin" for your drive.
See also viewtopic.php?p=148204#p148204
Galvin
#95 Post by Galvin » Thu Feb 20, 2025 4:13 pm
Coopervid wrote: Sun Feb 16, 2025 6:13 pm
Galvin wrote: Sun Feb 16, 2025 4:37 pm Sorry, I don't usually use the forums too much, my experience with ripping is based on the use of my Verbatim 43888, which does not have to be modified. I already have a good number of digitized titles and I had almost no problems until I reached a couple of discs from the Game of Thrones series, with which I tried several of the tips given in this forum regarding cleaning the discs without a positive result. As a consequence, I decided to buy another reader that I saw on Amazon at a good price, the one mentioned in the post, although this one needs to be modified to read UHD discs. I would appreciate any advice on this, thank you and best regards.
PM sent.
audiosync
#96 Post by audiosync » Mon Feb 24, 2025 10:32 pm
Coopervid wrote: Sun Feb 16, 2025 6:18 pm PM sent.
@Coopervid, would you mind pm'ing me with the necessary additional details to flash? I have the SDFtool flasher (v1.3.5), the ASUS_ODD_FW_Changer_(Modified) (24.08.2019), and the following firmware which I could flash (ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin). As you're aware, the SDFtool flasher doesn't work, as it's not the MT1959 platform.
Should I utilize the ASUS_ODD_FW_Changer? Wanted to make sure I didn't update it to one of the latest firmware's, and then not be able to go back.
Really would appreciate your insight. Cheers
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ...
Firmware date: 2015-10-20
Drive platform: RS8600
Firmware version: E101/ID76
#97 Post by Coopervid » Tue Feb 25, 2025 11:06 am
audiosync wrote: Mon Feb 24, 2025 10:32 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ...
PM is coming.
PCGold
#98 Post by PCGold » Tue Feb 25, 2025 5:53 pm
I apologize for the extremely noobie question but is there some special trick to actually find and download the firmware? I just got the ASUS everyone seems to like and have the loader to keep it simple but it points to my system looking for the firmware to use.
Thanks for the leg up🙂
#99 Post by Coopervid » Tue Feb 25, 2025 6:27 pm
PCGold wrote: Tue Feb 25, 2025 5:53 pm I apologize for the extremely noobie question but is there some special trick to actually find and download the firmware? I just got the ASUS everyone seems to like and have the loader to keep it simple but it points to my system looking for the firmware to use.
You need to post your Makemkv info.
PCGold
#100 Post by PCGold » Tue Feb 25, 2025 6:32 pm
Sorry but not sure what you mean by MakeMkv info... If the question is firmware version for the ASUS it is 3.10 I think.
#101 Post by dcoke22 » Tue Feb 25, 2025 6:38 pm
PCGold wrote: Tue Feb 25, 2025 6:32 pm Sorry but not sure what you mean by MakeMkv info... If the question is firmware version for the ASUS it is 3.10 I think.
He means the data about your drive from the first screen of MakeMKV. The information on the right side of the screen. Two sections, 'Drive Information' and 'LibreDrive Information'.
PCGold
#102 Post by PCGold » Tue Feb 25, 2025 6:53 pm
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLANBJI1457
#103 Post by Coopervid » Tue Feb 25, 2025 7:26 pm
PCGold wrote: Tue Feb 25, 2025 6:53 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
This is a LG drive. I guess a full size 5,25" drive in an enclosure. If so, flash LG WH16NS60 1.02.
Read this:
PCGold
#104 Post by PCGold » Tue Feb 25, 2025 8:00 pm
Thanks a ton. Looks like it was already live and could have found this but did not. Sorry about that... I ran searches and likely was just buried in more info that I am only beginning to grasp. As an IT person we cannot know all so love the help from the experts with experience.
I look forward to setting up my Plex server with ripped data... Wife will be shocked at all this...quite easy really 😃
jinx100
#105 Post by jinx100 » Tue Feb 25, 2025 8:02 pm
@Greenleaf says success using the ASUS-BW-16D1HT-3.10 firmware with this drive. See viewtopic.php?f=16&t=22896&p=169224&hil ... +U#p169224
Use Marty's SDFtool Flasher viewtopic.php?f=16&t=22896
And either Marty's "All You Need Firmware Pack" on the above page and select: DE_ASUS_BW-16D1HT_3.10_MK.bin
Or BillyCarr's "All you need firmware pack" on viewtopic.php?f=16&t=19634 and choose: ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
