How can I save a DVD to folder structure?
bpow1920
Post by bpow1920 »
I've tried to backup a DVD to folder structure but the app so far is only making a ISO file. Is this option not possible with a DVD? If so, how can I do it? Thanks.
Re: How can I save a DVD to folder structure?
As you stated, when MakeMKV does a backup of a DVD, it produces an .iso file. I'm not aware of any way to change that.
I would suppose you could mount the .iso file and copy the contents into a folder if you really wanted to.
drxenos
Post by drxenos »
bpow1920 wrote:
Sat Feb 22, 2025 7:26 pm
I usually just use Xreveal or AnyDVD to create a DVD folder. But can do it in two steps with MakeMKV. Generate an .iso file, then extract it with 7zip, WinRAR, WinZip, ISO Buster, etc.
bpow1920
Post by bpow1920 »
So extracting the iso is essentially making a folder structure? I was used to make it with AnyDVD and only used MakeMKV for the video files. And now I want to change the program for Xreveal or MakeMKV.
drxenos
Post by drxenos »
bpow1920 wrote:
Mon Feb 24, 2025 10:09 pm
Yup. Just extract it and you'll have the folder structure (or use Xreveal which will do it directly).
