National treasure rip not working
Nscribble64
Post by Nscribble64 »
I have two copies of a national treasure Blu-ray. It’s one of my favorite movies so when I tried to rip the Blu-ray instead of the DVD that I have it will stop it is one specific spot on both discs both discs look very clean and I don’t know why it will not rip. I have a flashed WP50nb40 for 4k
Re: National treasure rip not working
National Treasure (2004) blu-ray seems to be a dual-layer disc. If I had to guess, I would guess the optical drive is stalling out at the layer change, probably about half way through.
Nscribble64
It is around half but it does triple layer UHd’s and dual layers all the time and night at the museum Battle of the Smithsonian around the same spot
Nscribble64
dcoke22 wrote:National Treasure (2004) blu-ray seems to be a dual-layer disc. If I had to guess, I would guess the optical drive is stalling out at the layer change, probably about half way through.
That’s weird because it will do triple layer UHD disks just fine every time and it’ll do dual layers some times there’s a couple other movies that didn’t work either
Nscribble64
Probably most of my other movies will do the same thing, is there a way to fix it?
You could try gently cleaning the disc. Personally, when I have to clean a disc I use liquid dish soap and plenty of warm water. I lightly use my fingertip going back and forth from the inside to the outside and back again. I rinse with lots of water to remove all the soap then lay the disc label side down on a towel and used canned air to dry the data side. Make sure the disc is dry before it goes back into the optical drive.
If cleaning the disc doesn't work, trying the disc in a different drive might help. In my experience the same disc in a different drive sometimes produces different results. Not always, of course, but often. It seems like some drives just don't like some discs. The biggest improvement to my success rate for ripping discs came when I added a second, different drive.
Nscribble64
dcoke22 wrote:You could try gently cleaning the disc. Personally, when I have to clean a disc I use liquid dish soap and plenty of warm water. I lightly use my fingertip going back and forth from the inside to the outside and back again. I rinse with lots of water to remove all the soap then lay the disc label side down on a towel and used canned air to dry the data side. Make sure the disc is dry before it goes back into the optical drive.
I tryed that and it didn’t work and I am too broke to get another drive ngl is there a way to make it work on the one I have
BrettTheRipper
Post by BrettTheRipper »
Nscribble64 wrote:
Tue Feb 25, 2025 6:54 pm
I doubt it if you've already cleaned it and made multiple attempts. And I know you said you can't afford to buy another drive, but I'll mention anyway that I successfully ripped National Treasure on Blu-Ray using the BP50NB40 model that's currently on sale at Best Buy for $80. Good luck.
Nscribble64
I got a different one and it worked but now I have 3 copy’s ImageImage
Back_up_AZ
Post by Back_up_AZ »
[DiscID]: 0x06D890928926D92955883CD08C0D50B17F3882DF
[Volume]: = NATIONAL_TREASURE
[Date]: 2008-02-26
[MediaKey]: 0xF58B837C472A7CD4A427F9A44BD415EF
[VID]: 0x22304B636126065C576CC35B8352923D
[VUK]: 0x0A43E0E34DC1E7744AF1F1E1BDA874C9
[UnitKey]: 1-0x93B8B31F37C0930C2EE261E42FF6A8FC
[MKB]: 7/
[Size]: 48907223040
[MakeMKV SUPPORTED]: TRUE
