eBay seller screwed up my Blu-ray drive
akwmgp
Post by akwmgp »
Hello everyone,
I purchased a dell desktop on eBay (mistake #1) and it came with a LG BH16NS40 drive.....or so I thought. I took the drive out today and discovered that the real drive is an HP BD-RE BH40N. Sadly the seller updated the firmware to the 1.05 for the BH16NS40 and now the drive won't read any discs. Is there a way that I can fix this drive so It can read discs again or do I need to buy a new one?
Re: eBay seller screwed up my Blu-ray drive
How is the drive hooked up?
Please link any adapter are using
akwmgp
Post by akwmgp »
It's using the sata cables from the factory. This desktop shipped with a BD-RE drive (Dell Precision T1700).
akwmgp wrote:
Mon Feb 24, 2025 12:28 am
whats the build date on the drive
akwmgp
Post by akwmgp »
Billycar11 wrote:
Mon Feb 24, 2025 3:00 am
December 2014
akwmgp wrote:
Mon Feb 24, 2025 4:30 am
December 2014
Yeah there is your issue they did not test that at all 2016 is safe cut off date would have never worked and can't be fixed without dosflash and ide mode.
Just file a change back on eBay or cc or return it.
And for your next drive buy from ond of the recommend sellers in the guide see below
akwmgp
Post by akwmgp »
Billycar11 wrote:
Mon Feb 24, 2025 8:25 pm
December 2014
I will file a change back asap. That's the issue with eBay. People are only out for a quick buck. Thank you for all your help.
LunaBreeze
Post by LunaBreeze »
As I'm reading more on drives, I'm learning that drives automatically update when the owner pops in a new Blu ray disc? How would one prevent these updates from taking place? Would flashing a custom firmware prevent these updates from happening down the line?
LunaBreeze wrote:
Tue Feb 25, 2025 7:47 am
Drives do not update their firmware when you insert a blu-ray. A person has to choose to update the firmware of a drive. If you get a LibreDrive enabled drive and then don't update the firmware on it, you'll be fine.
LunaBreeze
dcoke22 wrote:
Tue Feb 25, 2025 5:01 pm
I see, I might be confusing firmware updates with AACS... is there a good resource to understand how things like this work in the blu-ray world?
