Hi All, I'm hoping for some help. I just had a new Vebatim Drive Delivered 43888. I tried to flash it today but I get the error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." I'm trying to install the firmware DE_LG_BU40N_1.03_MK.bin
These are the drive details;
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOAOB1F5013
Any help or guidance would be massively apprecitated. I'm hoping to back up my 4k discs. Cheers.
zittrig
Re: SDFtool Flasher
Did you have checked "enc"?
Re: SDFtool Flasher
This is weird. The drive platform information is missing in your Makemkv info which suggests that this drive is based on a nwe chipset instead of MT1959. Then it can't be flashed. I suggest to return it. What's your country of residence?shieldsup wrote: Mon Feb 24, 2025 12:29 pm Hi All, I'm hoping for some help. I just had a new Vebatim Drive Delivered 43888. I tried to flash it today but I get the error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." I'm trying to install the firmware DE_LG_BU40N_1.03_MK.bin
Revision: 1.05
shieldsup
Re: SDFtool Flasher
I'm in Australia. Bought it through Amazon.com.au
shieldsup
Re: SDFtool Flasher
I opened up Makemkv on my Mac and this is what it tells me;
OS device name: /dev/rdisk2
Revision: 1.05
Serial number: *******
Highest AACS version: 77
Revision: 1.05
shieldsup
Re: SDFtool Flasher
I bought the drive in Australia from Amazon.com.auCoopervid wrote: Mon Feb 24, 2025 5:41 pmThis is weird. The drive platform information is missing in your Makemkv info which suggests that this drive is based on a nwe chipset instead of MT1959. Then it can't be flashed. I suggest to return it. What's your country of residence?shieldsup wrote: Mon Feb 24, 2025 12:29 pm Hi All, I'm hoping for some help. I just had a new Vebatim Drive Delivered 43888. I tried to flash it today but I get the error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." I'm trying to install the firmware DE_LG_BU40N_1.03_MK.bin
Revision: 1.05
Revision: 1.05
shieldsup
Re: SDFtool Flasher
That's the problem I thought I had there are a lot of different scenarios but I got that error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." So am I missing a step or did I not do something right?
Re: SDFtool Flasher
Post your command line. There's also an override but I'm not good with Mac computers.shieldsup wrote: Tue Feb 25, 2025 11:42 pmThat's the problem I thought I had there are a lot of different scenarios but I got that error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." So am I missing a step or did I not do something right?
shieldsup
Re: SDFtool Flasher
Sorry I did this using the SDFtool Flasher Windows GUI Tool not on the mac. I use Parrallels which allows me to have a Windows machine on my Mac as well. Does it have something to do with the 1.05 version of the drive and the Flash Firmware is 1.03?Coopervid wrote: Tue Feb 25, 2025 11:44 pmPost your command line. There's also an override but I'm not good with Mac computers.shieldsup wrote: Tue Feb 25, 2025 11:42 pmThat's the problem I thought I had there are a lot of different scenarios but I got that error message "The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed." So am I missing a step or did I not do something right?
onkloud9
Re: SDFtool Flasher
Thanks Marty McNuts, it worked!
I got an error during the second flash but my BP50NB40 works perfectly.
Re: SDFtool Flasher
I'd be surprised if flashing firmware worked via Parallels.shieldsup wrote: Wed Feb 26, 2025 12:13 am Sorry I did this using the SDFtool Flasher Windows GUI Tool not on the mac. I use Parrallels which allows me to have a Windows machine on my Mac as well. Does it have something to do with the 1.05 version of the drive and the Flash Firmware is 1.03?
swkeith
Re: SDFtool Flasher
Just followed the guide and used the software to flash my WP50NB40 to the BU40N. Holy cow that was easy, can't believe I waited so long to try it. Currently in the middle of ripping my first UHD and then will try and rip a regular BD to confirm that still works. Thanks so much for all the work on this!
Re: SDFtool Flasher
You're welcome! Enjoy!!swkeith wrote: Sat Mar 01, 2025 10:43 pm Just followed the guide and used the software to flash my WP50NB40 to the BU40N. Holy cow that was easy, can't believe I waited so long to try it. Currently in the middle of ripping my first UHD and then will try and rip a regular BD to confirm that still works. Thanks so much for all the work on this!
Re: SDFtool Flasher
SDFtool Flasher updated to v1.3.6. Just a couple of code adjustments and minor bug fixes.
Any issues using it, you can go back to the previous version. Download links for both are in the first post.
