Baking FEL requires re-encoding so what you're asking is not possible.
An untouched FEL remux can only be played properly on a device that can decode it.
Just get the Ugoos if you want the best quality without compromise.
nekno
Post by nekno »
darrrkmanxxx wrote:
Sun Feb 09, 2025 3:21 pm
Honestly I'm getting exactly the same behavior with Prores422 on macos in resolve when I let it do it the background while working with other apps.
Resolve only does it's job when I leave the computer completely untouched. So resolve is very unreliable in that way.
That's odd. Once transcoding to ProRes I haven't had any issues with Resolve on Windows or macOS, but can't say whether I specifically foregrounded another app. I definitely did while transcoding with FFMPEG, but that's it.
valington
Post by valington »
RESET_9999 wrote:
Mon Feb 10, 2025 6:23 pm
Reset which workflow for container mkv p5 profile dolby vision to make container mp4 p5 profile dolby vision
all the workflows are explained on the github or doom9 website...
https://forum.doom9.org/showthread.php?t=185317
MODE.B (5) =
BATCH MUXER
Can batch mux any DV source to TS or MP4
MKV/MP4 to TS
MKV/TS to MP4
powdeau
Post by powdeau »
If a video has this static metadata,
would it be more accurate to watch it on G4 in HDR10
or in generated DV?
low nits dolby vision metadata like this won't have any effect on a bright TV like the G4 so it doesn't matter.
staknhalo
Post by staknhalo »
in case anyone didn't hasn't noticed - hdr10plus tool now has an editor like dovi_tool for syncing/adding/removing metadata - thanks quietvoid :)
Donpoku
Post by Donpoku »
RESET_9999 wrote:
Sat Feb 15, 2025 2:11 pm
Hi with coreelec cpm test build which option allows L5 metadata & can still see osd/subtitles on an old lg c6. I.e source, 0 etc. I tried few of those options but can't get osd to show.. and do we still need autostart.sh cmd? Thanks.
the public A13 build doesnt have the option to have L5 set to 0, it's either L5 or no L5.
I don't know when he will release A14 but in the private builds, the UI now has all the options for L5. There's an option to use the original L5 values and when the OSD is triggered, it switches to 0 so it doesn't mask anything. No we don't need the autostart.sh anymore.
Donpoku
Post by Donpoku »
RESET_9999 wrote:
Fri Feb 21, 2025 2:53 am
Thank you, sent you a pm.
kazuma
Post by kazuma »
what is better? a good 2160p DV webrip or 1080P remux file? Which one you guys will prefer?
quietvoid
Post by quietvoid »
kazuma wrote:
Sat Feb 22, 2025 3:28 pm
Whichever is HDR.
daffie
Post by daffie »
If the webrip is DV I would prefer it over a 1080p remux. But only because of the DV. In terms of resolution/compression I would take a 1080p remux over a 2160 webrip every time.
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
darrrkmanxxx
Post by darrrkmanxxx »
with RPU L1 Like this and having only l2 trim for 100nits:
Will it clip on a 600-900 nit device?
Should I go for cm_analyze in this case and just transfer over L1 from this RPU?
No, it won't clip. Why do you think it would?
L1 and MDL are ok, L2 100nits will get extrapolated to your TV target
