eBay seller screwed up my Blu-ray drive
akwmgp
Post by akwmgp » Sun Feb 23, 2025 7:58 pm
Hello everyone,
I purchased a dell desktop on eBay (mistake #1) and it came with a LG BH16NS40 drive.....or so I thought. I took the drive out today and discovered that the real drive is an HP BD-RE BH40N. Sadly the seller updated the firmware to the 1.05 for the BH16NS40 and now the drive won't read any discs. Is there a way that I can fix this drive so It can read discs again or do I need to buy a new one?
Re: eBay seller screwed up my Blu-ray drive
Post by Billycar11 » Sun Feb 23, 2025 11:13 pm
How is the drive hooked up?
Please link any adapter are using
akwmgp
Post by akwmgp » Mon Feb 24, 2025 12:28 am
It's using the sata cables from the factory. This desktop shipped with a BD-RE drive (Dell Precision T1700).
Post by Billycar11 » Mon Feb 24, 2025 3:00 am
akwmgp wrote: Mon Feb 24, 2025 12:28 am It's using the sata cables from the factory. This desktop shipped with a BD-RE drive (Dell Precision T1700).
whats the build date on the drive
akwmgp
Post by akwmgp » Mon Feb 24, 2025 4:30 am
Billycar11 wrote: Mon Feb 24, 2025 3:00 am
December 2014
Post by Billycar11 » Mon Feb 24, 2025 8:25 pm
akwmgp wrote: Mon Feb 24, 2025 4:30 am
December 2014
Yeah there is your issue they did not test that at all 2016 is safe cut off date would have never worked and can't be fixed without dosflash and ide mode.
Just file a change back on eBay or cc or return it.
And for your next drive buy from ond of the recommend sellers in the guide see below
akwmgp
Post by akwmgp » Mon Feb 24, 2025 11:52 pm
Billycar11 wrote: Mon Feb 24, 2025 8:25 pm
December 2014
I will file a change back asap. That's the issue with eBay. People are only out for a quick buck. Thank you for all your help.
LunaBreeze
Post by LunaBreeze » Tue Feb 25, 2025 7:47 am
As I'm reading more on drives, I'm learning that drives automatically update when the owner pops in a new Blu ray disc? How would one prevent these updates from taking place? Would flashing a custom firmware prevent these updates from happening down the line?
Post by dcoke22 » Tue Feb 25, 2025 5:01 pm
LunaBreeze wrote: Tue Feb 25, 2025 7:47 am As I'm reading more on drives, I'm learning that drives automatically update when the owner pops in a new Blu ray disc? How would one prevent these updates from taking place? Would flashing a custom firmware prevent these updates from happening down the line?
Drives do not update their firmware when you insert a blu-ray. A person has to choose to update the firmware of a drive. If you get a LibreDrive enabled drive and then don't update the firmware on it, you'll be fine.
LunaBreeze
Post by LunaBreeze » Tue Feb 25, 2025 7:34 pm
dcoke22 wrote: Tue Feb 25, 2025 5:01 pm
I see, I might be confusing firmware updates with AACS... is there a good resource to understand how things like this work in the blu-ray world?
