One DVD -> MKV giving audio glitch / discontinuity problems
mark007
#1 Post by mark007 » Wed Oct 14, 2009 11:13 pm
I have converted most of my DVD's to mkv now using makemkv and have had no problems until the last few days.
I am converting "The World Is Not Enough" DVD, but certain areas of the movie show audio glitches. These glitches have been confirmed by other users, and seem to be at particular points in the movie.
See thread below, where a user on the mpc-hc forums has visually shown the discontinuity glitch in this mkv.
http://forum.doom9.org/showthread.php?p ... ost1334699
I have a 1 minute sample, where approx 30 seconds into the clip you should hear a blip, or a sound distortion, depending on the player used.
http://www.megaupload.com/?d=3GZ9J6TZ
I would appreciate any input on this, as the only common piece of software that can be used to reproduce the glitch is unfortunately makemkv 1.4.8.
I have edited the mkv for other reasons with mkvmerge, and resaving doesn't seem to fix the issue.
Re: One DVD -> MKV giving audio glitch / discontinuity problems
#2 Post by mike admin » Thu Oct 15, 2009 10:38 am
I would ask you to do a lenghty step. Please enable "log debug messages" in preferences, convert the specific title from the disc to mkv again, and post the log file (it will be created by makemkv in your home directory) here. feel free to wipe personal info (username) from it. Also please confirm that 1.4.7 or any earlier version did not show this behaivor.
mark007
#3 Post by mark007 » Thu Oct 15, 2009 3:30 pm
Here is the log
003010:000000:0000 Using direct disc access mode
003020:000000:0000 Title #0 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #1 was added (33 cell(s), 2:02:39)
003020:000000:0000 Title #2 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #3 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #4 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #5 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #6 was added (6 cell(s), 0:15:01)
003020:000000:0000 Title #7 has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #8 was added (1 cell(s), 0:04:01)
003036:000000:0000 Title #9 was added (8 cell(s), 0:22:49)
003036:000000:0000 Title #10 was added (5 cell(s), 0:25:02)
003036:000000:0000 Title #11 was added (1 cell(s), 0:03:13)
003020:000000:0000 Title #12 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #13 was added (1 cell(s), 0:03:21)
003020:000000:0000 Title #14 has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #15 has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #16 has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #17 was added (1 cell(s), 0:02:44)
003020:000000:0000 Title #18 has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #19 was added (1 cell(s), 0:05:34)
003036:000000:0000 Title #20 was added (1 cell(s), 0:02:58)
003036:000000:0000 Title #21 was added (1 cell(s), 0:02:06)
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 11 titles into directory C:/testVideo/15767
001012:000000:0020 FAILURE: Code 1 at -)&6pavBKTTxFE/1S{I:121264602
005005:000000:0000 11 titles saved
I hope this helps. The disk itself is fine, i can copy with DVD Decrypter with no errors. Its like as if something like timecodes arn't accurate, giving audio glitches in certain parts of the mkv.
mark007
#4 Post by mark007 » Mon Oct 19, 2009 5:07 pm
Any ideas what this error means guys?
