[HELP] Flash LG WH14NS40 rev1.01
dngayan
#1 Post by dngayan » Sat Feb 22, 2025 5:04 pm
Good Day.
I have tried reading some of the post regarding flashing the FW for WH14NS40 to read/rip UHD disc(s). I am still fairly new with flashing drives but not PC bios. I have already dumped the fw of the drive to save a copy of it incase something went wrong. All I need now is guidance on what to do next.
Here is the makemkv information for my BDrive:
OS device name: F:
Product: BD-RE WH14NS40
Revision: 1.01
Serial number: ...
Firmware date: 2113-04-04 23:25
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
Here is the command i used to dump the original firmware: (did i do it right?)
makemkvcon64.exe f -d F: dump auto -o d:\bddump\
Operation started: Reading flash memory
100% Operation finished
Command produced 1 file(s)
#00: size=2048Kb name=dump_full_HL-DT-ST_BD-RE__WH14NS40_1.01_211304042325_K91D5S24928.bin
Re: [HELP] Flash LG WH14NS40 rev1.01
#2 Post by dcoke22 » Sun Feb 23, 2025 1:49 am
The Ultimate UHD Drives Flashing Guide says, right at the top, that the drive platform needs to be MT1959. Yours is MT1939. If you try to flash your drive, you'll probably break it.
dngayan
#3 Post by dngayan » Sun Feb 23, 2025 7:57 pm
dcoke22 wrote: Sun Feb 23, 2025 1:49 am The Ultimate UHD Drives Flashing Guide says, right at the top, that the drive platform needs to be MT1959. Yours is MT1939. If you try to flash your drive, you'll probably break it.
Thank you for letting me know. Appreciate your response.
