#10681 Post by RESET_9999 » Sat Feb 15, 2025 2:11 pm
low nits dolby vision metadata like this won't have any effect on a bright TV like the G4 so it doesn't matter.
staknhalo
#10682 Post by staknhalo » Sun Feb 16, 2025 6:39 pm
in case anyone didn't hasn't noticed - hdr10plus tool now has an editor like dovi_tool for syncing/adding/removing metadata - thanks quietvoid :)
Donpoku
#10683 Post by Donpoku » Fri Feb 21, 2025 1:55 am
Hi with coreelec cpm test build which option allows L5 metadata & can still see osd/subtitles on an old lg c6. I.e source, 0 etc. I tried few of those options but can't get osd to show.. and do we still need autostart.sh cmd? Thanks.
#10684 Post by RESET_9999 » Fri Feb 21, 2025 2:53 am
the public A13 build doesnt have the option to have L5 set to 0, it's either L5 or no L5.
I don't know when he will release A14 but in the private builds, the UI now has all the options for L5. There's an option to use the original L5 values and when the OSD is triggered, it switches to 0 so it doesn't mask anything. No we don't need the autostart.sh anymore.
Donpoku
#10685 Post by Donpoku » Fri Feb 21, 2025 5:16 am
Thank you, sent you a pm.
kazuma
#10686 Post by kazuma » Sat Feb 22, 2025 3:28 pm
what is better? a good 2160p DV webrip or 1080P remux file? Which one you guys will prefer?
quietvoid
#10687 Post by quietvoid » Sat Feb 22, 2025 6:37 pm
Whichever is HDR.
daffie
#10688 Post by daffie » Mon Feb 24, 2025 10:05 am
If the webrip is DV I would prefer it over a 1080p remux. But only because of the DV. In terms of resolution/compression I would take a 1080p remux over a 2160 webrip every time.
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
darrrkmanxxx
#10689 Post by darrrkmanxxx » Mon Feb 24, 2025 12:36 pm
with RPU L1 Like this and having only l2 trim for 100nits:
Will it clip on a 600-900 nit device?
Should I go for cm_analyze in this case and just transfer over L1 from this RPU?
#10690 Post by RESET_9999 » Mon Feb 24, 2025 1:11 pm
No, it won't clip. Why do you think it would?
L1 and MDL are ok, L2 100nits will get extrapolated to your TV target
#10691 Post by RESET_9999 » Mon Feb 24, 2025 11:14 pm
speaking of clipping on bluray players because they alter the RPU, I found a very good example: Dredd 2012 FEL BD is a very bright grade but the RPU MDL is 1000nits so clipping is visible on bluray players.
The ugoos with CPM A13+, and Shield do not clip...
did some samples https://drive.google.com/drive/u/1/fold ... MU3KAisiAm
daffie
#10692 Post by daffie » Tue Feb 25, 2025 9:22 am
Dredd 2012 is only HDR10, no ? See here https://www.blu-ray.com/movies/Dredd-4K ... ay/176582/
Do you have a link to a FEL BD for this movie? I don't think this was ever released in Dolby Vision on BD.
EDIT : sorry, there are Dolby Vision versions in the German and Italian releases :-)
deadchip12
#10693 Post by deadchip12 » Wed Feb 26, 2025 2:38 am
@RESET_9999
In your RPU folder, the file named "Pearl.2022.BD_Generated_OSC" is Bluray rpu with cmv 4.0 already transferred? What does OSC mean?
skull88
#10694 Post by skull88 » Wed Feb 26, 2025 3:52 am
OSC = Original Scene/Shot Cuts i.e. not generated but retailed sourced, whether WEB-DL or UHD BD.
deadchip12
#10695 Post by deadchip12 » Wed Feb 26, 2025 5:17 am
So Pearl.2022.BD_Generated_OSC means it's the original rpu from UHD BD? How come it's cmv 4.0?
