Verbatim (Pioneer) Slimline BDXL drive - Is UHD playback/ripping possible?
potito
Post by potito » Fri Feb 21, 2025 4:29 pm
Hello, I was wondering if my drive was capable of ripping UHD discs since when I try to insert one the drive just spits it out.
Thanks in advance!
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Re: Verbatim (Pioneer) Slimline BDXL drive - Is UHD playback/ripping possible?
Post by Coopervid » Fri Feb 21, 2025 4:52 pm
potito wrote: Fri Feb 21, 2025 4:29 pm Hello, I was wondering if my drive was capable of ripping UHD discs since when I try to insert one the drive just spits it out.
Thanks in advance!
Revision: 1.14
Serial number:
PM sent.
polek
Post by polek » Fri Feb 21, 2025 8:18 pm
Hi!
I'm having similar problem with my Verbatim 43888.
It works fine with 4k Blu-Ray like Ocean's 8 but cannot even read Slowhand at 70 4K - it keeps spining up and down or behave like there is no blu-ray inside. Sometimes after few tries it will work for few seconds but not enought to lounch MakeMKV.
Also I've tried another one exactly the same (new) drive and it behaved the same. After that I ordered another one Slowhand at 70 4K. I even tried powered USB hub. All of it on few difrent computers and Mac. Normal Blu-Rays work just fine. Should I change my drive to ASUS BW-16D1HT or is there any way to get it to work?
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number-----
Highest AACS version: 77
Drive platform: RS8A10
Post by MartyMcNuts » Fri Feb 21, 2025 10:23 pm
polek wrote: Fri Feb 21, 2025 8:18 pm Hi!
Revision: 1.14
Serial number-----
It's not the drive, it's the disc. Clean the disc and see if that helps.
polek
Post by polek » Fri Feb 21, 2025 11:57 pm
Thanks for response :) Both discs were brand new and cleaned with microfiber cloth from any residue before every try.
Post by Coopervid » Wed Feb 26, 2025 10:32 am
polek wrote: Fri Feb 21, 2025 11:57 pm Thanks for response :) Both discs were brand new and cleaned with microfiber cloth from any residue before every try.
Wash them with warm water and liquid soap. Dry with a paper towel. Wipe with a microfiber cloth.
And make sure this drive gets enough power. Best via USB-C or a powered USB hub.
user1842
Post by user1842 » Fri Apr 24, 2026 7:45 pm
Can I get a PM too :D
Revision: 1.11
Serial number: TGDL332793WL
Firmware date: 2018-11-28
Firmware version: 1.11
Post by Billycar11 » Fri Apr 24, 2026 9:56 pm
user1842 wrote: Fri Apr 24, 2026 7:45 pm Can I get a PM too :D
Revision: 1.11
Sure email me that drive info section see below for email
No need to post your info publicly just email me directly for pioneers
