Thanks! Which reminds me, it's about time for an update...John7 wrote: Wed Mar 20, 2024 3:46 pm This is a superb resource. Thank you so much for creating it and taking the time to update it. Bravo!
All 4K Releases Spreadsheet
Re: All 4K Releases Spreadsheet
Have you made changes to permissions? I opened the spreadsheet a month ago and it allowed me to sort the reference disk entries, but today it does not.
jtsapps217
Super helpful spreadsheet, thanks for posting.
PotatoKing
Awesome! Thanks!
SljivovitzDino
Be great to get an update!
kevingroover
would you be open to adding files sizes for 4k uhd rips?
So this is just a conversion from a blog page on The Digital Bits, nothing in here is entered manually. If they had that data I’d pull it in! Do you know if there’s somewhere I can get that info and automate it?kevingroover wrote: Wed Feb 19, 2025 2:05 am would you be open to adding files sizes for 4k uhd rips?
It isn't very useful since it will depend on whether you rip all the audio tracks or not.kevingroover wrote: Wed Feb 19, 2025 2:05 am would you be open to adding files sizes for 4k uhd rips?
Really nice spreadsheet, thanks!
FleshedPeso2586
There's The Disc DB, which has its source data on GitHub, but it only covers a fraction of the movies on the sheet.Cannikin wrote: Wed Feb 19, 2025 2:23 am Do you know if there’s somewhere I can get that info and automate it?
The Lord of the Rings Trilogy is stated as native 4k in the list, but detailed analyses of the 4K version suggest it was upscaled and AI enhanced and no new 4k scan of the original negatives:
https://youtu.be/I3Z58uiwcME?t=329
https://youtu.be/zkNFZkUHeKQ?t=366
So I doubt that Lord of the Rings really is native 4k.
Is there a version of this database with information on the MKB version on each release?
Not that I'm aware of, this is just the info from https://thedigitalbits.com/columns/the- ... lease-list turned into spreadsheet form.VA1DER wrote: Thu May 08, 2025 4:14 pm Is there a version of this database with information on the MKB version on each release?
This community is amazing honestly
