command for lg slim bp60nb10 svc code nb12 on windows powershell 86
Re: command for lg slim bp60nb10 svc code nb12 on windows powershell 86
Luckkyfox wrote: Mon Feb 17, 2025 5:18 am
dcoke22 wrote: Mon Feb 17, 2025 4:26 am
Luckkyfox wrote: Mon Feb 17, 2025 4:20 am where can i use/find ur firmware pack ?
See the first post in MartyMcNuts's SDFtool Flasher thread: https://forum.makemkv.com/forum/viewtopic.php?f=16&t=22896
it went thru again still isn't letting me burn things says the same thing about the disc
Please explain. Your sentence makes no sense.
Luckkyfox
Post by Luckkyfox »
MartyMcNuts wrote: Mon Feb 17, 2025 6:06 am
my bad i was half asleep your firmware worked thank you so much for your help I'm able to download my stuff now!
Luckkyfox wrote: Mon Feb 17, 2025 7:08 pm
What do you mean download? Do you actually mean you can rip UHD discs now?
Luckkyfox
Post by Luckkyfox »
MartyMcNuts wrote: Mon Feb 17, 2025 10:40 pm
not uhd cuz my pc isn't powerful enough for that so i haven't tried but I've done bad boys & sound of metal
Luckkyfox wrote: Tue Feb 18, 2025 3:48 am
You don't need a powerful PC to rip UHD discs. For playback, yeah sure but any old PC that can rip BD can rip UHD.
Luckkyfox
Post by Luckkyfox »
MartyMcNuts wrote: Tue Feb 18, 2025 6:40 am
oh ok fs thanks for letting me know & thanks for the help.
btw do u know any software i can download to burn discs or do i just use the one the lg slim makes u buy/comes with?
Luckkyfox wrote: Tue Feb 18, 2025 4:21 pm
There's plenty of burning software around. ImgBurn is good. There's others like Nero, Ashampoo Burning Studio etc.
Luckkyfox
Post by Luckkyfox »
MartyMcNuts wrote: Tue Feb 18, 2025 9:45 pm
is there any pros & cons for them/ Would i have to figure out what works with me? or are they more or less the same
& fs ill be checking out ImgBurn
Luckkyfox wrote: Thu Feb 20, 2025 5:18 pm
Check out ImgBurn first. Then if you decide you want something else. start looking at the others.
