Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
#2746 Post by Billycar11 » Thu Feb 20, 2025 5:39 am
cf1084 wrote: Thu Feb 20, 2025 4:51 am I bought this unit and was able to record a UHD BD (so it says on the box), but I tried other movies and it doesn't read them... what can I do?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-213M
Revision: 1.05
Serial number: ****
Firmware date: 2023-08-01
Highest AACS version: 68
Drive platform: Pioneer RS9200
Firmware version: ID56
nah you didnt read a UHD with that
you did a regular BD
cf1084
#2747 Post by cf1084 » Thu Feb 20, 2025 5:43 am
U rigth i realized after the post 😵‍💫😵‍💫… however is anything i can do to read the UHD??
Mr_Orange
#2748 Post by Mr_Orange » Thu Feb 20, 2025 11:16 am
Billycar11 wrote: Thu Feb 20, 2025 5:39 am
OS device name: E:
Revision: 1.05
Serial number: ****
He said "record" not "rip", unless he meant "rip".
#2749 Post by Billycar11 » Thu Feb 20, 2025 11:39 am
Mr_Orange wrote: Thu Feb 20, 2025 11:16 am
i didnt say rip but yeah that drive will not see a UHD disc at all unless you buy it from me marty or asmcom and the drive info will not look like that at all
its not an official UHD drive so it does not see those discs
Mr_Orange
#2750 Post by Mr_Orange » Thu Feb 20, 2025 11:47 am
Billycar11 wrote: Thu Feb 20, 2025 11:39 am
True, you said "read" but fundamentally there is no difference between "read" and "rip" since ripping requires reading. If the drive doesn't even recognise a UHD then, I concede, that it wouldn't record either.
shinkiro
#2751 Post by shinkiro » Thu Feb 20, 2025 7:24 pm
zittrig wrote: Thu Feb 20, 2025 4:18 am
shinkiro wrote: Wed Feb 19, 2025 6:48 am Hi guys, I just got the Buffalo Japanese drive "BRUHD-PU3" (external) but I don't know which tool or firmware to use to read UHD blu-ray discs.
Do I use the flasher on this thread: viewtopic.php?f=16&t=22896 or something else entirely?
I saw that "MartyMcNuts" said to use "1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
2. DE_Buffalo_BRUHD-PU3_BU10 OR DE_LG_BU40N_1.00", so any of these three firmwares work?
Show drive information with MakeMKV.
Here you go:
OS device name: M:
Current profile: DVD-ROM
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: MO7NBNG5633
Firmware date: 2121-06-21 13:30
Bus encryption flags: 1F
zittrig
#2752 Post by zittrig » Thu Feb 20, 2025 9:22 pm
Try flashing with LG BU40N 1.03MK.
DrakkerFlight
#2753 Post by DrakkerFlight » Fri Feb 21, 2025 1:06 am
Oh wow I guess I missed this firmware was on the encrypted list. Add enc seems to have fixed the issue. Thank you!
shinkiro
#2754 Post by shinkiro » Fri Feb 21, 2025 3:52 pm
zittrig wrote: Thu Feb 20, 2025 9:22 pm Try flashing with LG BU40N 1.03MK.
Any idea if my current firmware is encrypted or not?
zittrig
#2755 Post by zittrig » Fri Feb 21, 2025 4:02 pm
It is, check "enc" if not checked automatically.
tjones85
#2756 Post by tjones85 » Fri Feb 21, 2025 4:38 pm
Hey All,
Bit of a newb at this. Im looking to regenerate my macbook pro mid 2009 and have it as my ripper for my media libarary.
Anyone know if this would support make MKV?
https://www.amazon.co.uk/dp/B07TG9CBR8/ ... _lig_dp_it
Or anyone know of an internal drive for my MBP that would?
Thanks in advance
zittrig
#2757 Post by zittrig » Fri Feb 21, 2025 5:34 pm
No, this drive is not 4k flashable.
#2758 Post by dcoke22 » Fri Feb 21, 2025 5:51 pm
tjones85 wrote: Fri Feb 21, 2025 4:38 pm Hey All,
A 2009 era MacBook Pro probably has USB 2.0 ports on it. You could easily get 'full sized' desktop style drive and put in a powered external case and plug it into the USB port on the side of your MBP.
Something like the OWC Mercury Pro enclosure or a Vantec NexStar DX2 enclosure will hold an optical drive, power it, and allow it to be connected to any computer over USB.
Going this route is probably a better choice than trying to jam something into the innards of your old MBP. With the drive in an external enclosure, you can easily move it when a mac Mini replaces that old MBP. :)
tjones85
#2759 Post by tjones85 » Sat Feb 22, 2025 12:42 am
Ah okay thanks so those drives are flashable and will enable me to run MakeMKV?
jspace
#2760 Post by jspace » Sat Feb 22, 2025 12:45 am
Big thanks to MartyMcNuts and the other devs for the SDF tool. Getting a WH14NS40 to rip UHDs was super easy. :D
