you forgot encDrakkerFlight wrote: ↑Thu Feb 20, 2025 3:37 amI appreciate your quick replies and help. I tried refreshing multiple times. Each time it says the flash is successful but the Status hasn't changed to enable. Below is what the terminal output looks like (This is on a Mac mini M2). I followed the Mac flashing command instructions under the "How To Flash Videos and commands:" section on this guide.
Do I need to revert back to the original firmware (not sure where to get the from) before attempting to flash back?
MacOS % ./makemkvcon f -d '/IOBDServices/2D033E1B' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin Reading input file /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Current Drive ID: HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM04OBKC5309 Using USB chipset workaround for Desktop drive handshake Ready to write drive flash memory. Type "yes" to continue, "no" to abort yes Operation started: Sending flash image to drive 100% Operation finished Operation started: Programming flash 100% Operation finished Done successfully
Ultimate UHD Drives Flashing Guide Updated 2025
I bought this unit and was able to record a UHD BD (so it says on the box), but I tried other movies and it doesn't read them... what can I do?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-213M
Revision: 1.05
Serial number: ****
Firmware date: 2023-08-01
Highest AACS version: 68
Drive platform: Pioneer RS9200
Firmware version: ID56
OS device name: E:
Revision: 1.05
Serial number: ****
nah you didnt read a UHD with thatcf1084 wrote: ↑Thu Feb 20, 2025 4:51 amI bought this unit and was able to record a UHD BD (so it says on the box), but I tried other movies and it doesn't read them... what can I do?
OS device name: E:
Revision: 1.05
Serial number: ****
you did a regular BD
U rigth i realized after the post
… however is anything i can do to read the UHD??
He said "record" not "rip", unless he meant "rip".Billycar11 wrote: ↑Thu Feb 20, 2025 5:39 amnah you didnt read a UHD with thatcf1084 wrote: ↑Thu Feb 20, 2025 4:51 amI bought this unit and was able to record a UHD BD (so it says on the box), but I tried other movies and it doesn't read them... what can I do?
OS device name: E:
Revision: 1.05
Serial number: ****
i didnt say rip but yeah that drive will not see a UHD disc at all unless you buy it from me marty or asmcom and the drive info will not look like that at all
its not an official UHD drive so it does not see those discs
True, you said "read" but fundamentally there is no difference between "read" and "rip" since ripping requires reading. If the drive doesn't even recognise a UHD then, I concede, that it wouldn't record either.Billycar11 wrote: ↑Thu Feb 20, 2025 11:39 ami didnt say rip but yeah that drive will not see a UHD disc at all unless you buy it from me marty or asmcom and the drive info will not look like that at all
Here you go:zittrig wrote: ↑Thu Feb 20, 2025 4:18 amShow drive information with MakeMKV.shinkiro wrote: ↑Wed Feb 19, 2025 6:48 amHi guys, I just got the Buffalo Japanese drive "BRUHD-PU3" (external) but I don't know which tool or firmware to use to read UHD blu-ray discs.
Do I use the flasher on this thread: viewtopic.php?f=16&t=22896 or something else entirely?
I saw that "MartyMcNuts" said to use "1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
2. DE_Buffalo_BRUHD-PU3_BU10 OR DE_LG_BU40N_1.00", so any of these three firmwares work?
OS device name: M:
Current profile: DVD-ROM
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: MO7NBNG5633
Firmware date: 2121-06-21 13:30
Bus encryption flags: 1F
Try flashing with LG BU40N 1.03MK.
Oh wow I guess I missed this firmware was on the encrypted list. Add enc seems to have fixed the issue. Thank you!
It is, check "enc" if not checked automatically.
Hey All,
Bit of a newb at this. Im looking to regenerate my macbook pro mid 2009 and have it as my ripper for my media libarary.
Anyone know if this would support make MKV?
https://www.amazon.co.uk/dp/B07TG9CBR8/ ... _lig_dp_it
Or anyone know of an internal drive for my MBP that would?
Thanks in advance
Thanks in advance
No, this drive is not 4k flashable.
A 2009 era MacBook Pro probably has USB 2.0 ports on it. You could easily get 'full sized' desktop style drive and put in a powered external case and plug it into the USB port on the side of your MBP.
Something like the OWC Mercury Pro enclosure or a Vantec NexStar DX2 enclosure will hold an optical drive, power it, and allow it to be connected to any computer over USB.
Going this route is probably a better choice than trying to jam something into the innards of your old MBP. With the drive in an external enclosure, you can easily move it when a mac Mini replaces that old MBP.
