Is my pioneer BDR-XD05s flashable?
pitt1717
Re: Is my pioneer BDR-XD05s flashable?
#61 Post by pitt1717 » Wed Feb 19, 2025 11:56 pm
pitt1717 wrote: Wed Feb 19, 2025 11:54 pm
Coopervid wrote: Wed Feb 19, 2025 11:02 pm Slow down and with some more posts you are elegible to do PMs. Then do so.
didn't know there was a post count for pm's. i guess i read to much into that post
anyway, i hope i didnt come across rude. just stating my position
pitt1717
#62 Post by pitt1717 » Thu Feb 20, 2025 12:15 am
ok, guess i have to make 1 more. pm sent
jaimelalone
#63 Post by jaimelalone » Sat Feb 22, 2025 10:41 pm
just another someone wanting to flash a drive...
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: PKDLxxxxxxUC
Firmware date: 2017-06-22
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
#64 Post by Coopervid » Sun Feb 23, 2025 2:12 pm
jaimelalone wrote: Sat Feb 22, 2025 10:41 pm just another someone wanting to flash a drive...
Revision: 3.10
PM sent.
bragger3001
#65 Post by bragger3001 » Sat Mar 08, 2025 4:41 am
bragger3001 wrote: Thu Feb 06, 2025 1:00 pm I have the same question. Thanks!
Here is my MakeMKV info:
Revision: 3.10
Serial number: ,,,
Highest AACS version: 61
#66 Post by Coopervid » Mon Mar 10, 2025 8:17 pm
bragger3001 wrote: Sat Mar 08, 2025 4:41 am
Revision: 3.10
Serial number: ,,,
PM sent.
bragger3001
#67 Post by bragger3001 » Tue Mar 11, 2025 4:19 am
Coopervid wrote: Mon Mar 10, 2025 8:17 pm
Revision: 3.10
Serial number: ,,,
PM sent.
I want to say thank you so much and verify that everything is working great as far as I can tell so far! Great work!
bragger3001
#68 Post by bragger3001 » Tue Mar 11, 2025 3:00 pm
bragger3001 wrote: Tue Mar 11, 2025 4:19 am
Revision: 3.10
Serial number: ,,,
PM sent.
Donation sent
#69 Post by Coopervid » Tue Mar 11, 2025 3:10 pm
Thank you!
Powerkey
#70 Post by Powerkey » Sun Mar 16, 2025 4:25 pm
Thank you, that worked great.
Does the flasher change anything in regard to region encoded Blu-ray discs?
I just purchased a European 4k Blu-ray Disc that comes with a Region B supplemental disc. Wondering if it will RIP it.
#71 Post by Coopervid » Sun Mar 16, 2025 8:33 pm
Powerkey wrote: Sun Mar 16, 2025 4:25 pm Thank you, that worked great.
Makemkv takes care of the region restrictions. Post your Makemkv info.
olditguy2025
#72 Post by olditguy2025 » Mon Mar 31, 2025 1:49 pm
I found this thread in a search and this is my first post on the forum. I too have this drive and checked it last night. It is working and still has the original firmware. I would like to flash it so it can read 4K discs. Can someone provide a link to the firmware for this drive? :)
Xrider
#73 Post by Xrider » Wed Apr 02, 2025 7:10 pm
Hello! I have a Pioneer BDR-XD05S (the S shows up on the sticker on the bottom) that was manufactured in january of 2017 (according to the sticker on the bottom) and I was wondering if it was possible to have flashed to work with UHD discs? The drive and libredrive information are as follows:
Informations lecteur
Nom du lecteur SE : E:
Fabricant : PIONEER
Produit : BD-RW BDR-XD05
Révision : 3.10
Date micrologiciel : 2017-06-22
Marqueurs d'encryptage bus : 1B
#74 Post by Coopervid » Wed Apr 02, 2025 9:45 pm
Xrider wrote: Wed Apr 02, 2025 7:10 pm Hello! I have a Pioneer BDR-XD05S (the S shows up on the sticker on the bottom) that was manufactured in january of 2017 (according to the sticker on the bottom) and I was wondering if it was possible to have flashed to work with UHD discs? The drive and libredrive information are as follows:
Fabricant : PIONEER
Révision : 3.10
PM sent.
SecurityDevice
#75 Post by SecurityDevice » Sun Apr 06, 2025 9:55 am
Wow, I am a total dummy. After getting a new computer, I was updating many things, and I saw there was new firmware available for my BDR-XD05S (manufactured March 2018). I did not do enough research beforehand, and immediately regretted my haste to "upgrade". This drive is no longer able to rip UHD BDs. Is there really no way to restore that functionality?
Revision: 3.11
Serial number: ...
Firmware date: 2023-03-03
Highest AACS version: 68
Drive platform: Pioneer RS8232
Firmware version: ID34
