KEY NOT PRESENT error
cryox
#1 Post by cryox » Sat Feb 01, 2025 1:56 pm
I'm receiving a lot of 'KEY NOT PRESENT' and some 'KEY NOT ESTABLISHED' errors using the linux version:
MakeMKV v1.17.8 linux(x64-release) started
Backing up disc into folder ...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Saved AACS dump file as ...
Backup failed
What I tried so far (always the same drive with the same BluRay):
Machine A (Arch) -> MakeMKV from AUR -> fails
Machine A (Arch) -> MakeMKV from Flatpak -> fails
Machine A (Arch) -> Ubuntu VM -> MakeMKV built as described here -> fails
Machine A (Arch) -> Windows VM -> MakeMVK from the website -> works
Machine B (Windows) -> MakeMVK from the website -> works
So I'm pretty confident there is something wrong with the Linux version. Also, since running it on a vanilla Ubuntu 24.10 VM using the manual as described doesn't work.
Has anyone faced a similar issue and was able to solve it?
Re: KEY NOT PRESENT error
#2 Post by dcoke22 » Tue Feb 11, 2025 2:52 pm
Is your drive LibreDrive compatible? Have you flashed it to enable LibreDrive?
hobbified
#3 Post by hobbified » Mon Feb 17, 2025 8:57 pm
Same thing here. Yes it's a compatible drive, a BRUHD-PU3-BK that I flashed. Rips work okay on MakeMKV 1.17.9 for Windows, but if I take the same drive and same disc and plug them into my Linux machine the copying process will start, then after a few seconds the drive spins down and there are a bunch of SCSI NOT READY errors, then when it spins up again it shows the KEY NOT PRESENT error several times. It continues copying data but the results are garbage. Kernel logs show
sr 7:0:0:0: Power-on or device reset occurred
at the same time. So it seems like it's essentially crashing the drive.
#4 Post by Woodstock » Mon Feb 17, 2025 9:51 pm
Another possibility is that it powered down, due to an over-speed condition. If the USB port isn't a "fully compatible" USB3 port, a drive can run out of power with only one plug inserted. This would tend to happen on a long read.
If it's happening right after the read starts, it would be strange.
cryox
#5 Post by cryox » Tue Feb 18, 2025 5:08 pm
Thanks for your suggestions! As indicated in the original post, the same drive, with the same firmware, same disc, same PC and same USB-Port works just fine when using Windows.
I can't really find any other reason than there is something missing or broken with the Linux version.
cryox
#6 Post by cryox » Wed Feb 19, 2025 1:36 pm
Problem still present in 1.17.9
I could further narrow it down: It works with normal Blu-rays (tested with AACS v28), but not with UHD Blu-rays (tested with AACS2.0/C v77).
The issue is probably related to how MakeMKV handles UHD decryption on Linux.
Can anyone give further hints to where to look for insights?
HeyQuitThat
#7 Post by HeyQuitThat » Mon Mar 03, 2025 1:37 am
Just to jump on this bandwagon, I'm seeing the same thing. Linux Mint 22.1 on x86_64. I'm running an LG BU40N with patched firmware 1.03MK. It rips DVDs OK in Linux but chokes on UHD. Same exact setup works in Windows. I'm running registered Make MKV 1.17.9.
#8 Post by dcoke22 » Mon Mar 03, 2025 5:40 am
I've seen it suggested on this forum that a BU40N needs to be flashed to firmware 1.00 to work the best on Linux.
https://forum.makemkv.com/forum/viewtopic.php?p=154090#p154090
bernie
#9 Post by bernie » Sun Jul 13, 2025 6:53 pm
Has there been any update to this issue?
I am experiencing the same problem on Linux. My system is Ubuntu 24.04.
I have tried multiple variants of the customized firmware, including version 1.03 from "The all you need firmware pack", as well as the DE 1.00 version suggested before. Both firmware versions result in this same error.
I've also tried both versions 1.18.1 and 1.17.7 without success. Version 1.17.7 is the only version which does not hang when flashing the firmware (issue appears to be reported here: viewtopic.php?p=174231#p174231).
The drive info on MakeMKV shows the drive as being LibreDrive enabled:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number: . . .
Highest AACS version: 66
Firmware version: 1.03
I have no trouble with traditional blu-ray discs, it is only 4k UHD discs that have this error. Unfortunately, I do not any Windows or Mac systems which I can try. Any ideas of any other next steps worth trying to see if I can get 4k UHD discs working in Linux?
bernie
#10 Post by bernie » Sun Jul 13, 2025 7:14 pm
Actually, I think I figured out my issue. Much like many others, I was able to get it to work with the older 1.00 firmware. The mistake I made before was flashing the firmware as encrypted (with the 'enc' flag). Apparently this flag was required when flashing to the original 1.03 firmware, but when going from 1.03 to 1.00, I suppose this is incorrect.
When I flashed the drive to use the 1.00 without the encrypted flag, it appears to work without issue.
Gk2011
#11 Post by Gk2011 » Mon Sep 22, 2025 5:29 am
I guess I'll try flashing my drive down to the older firmware for my BU40N 1.03v
I'm having the same issues as described in this thread after testing 4k RIPS on my windows machine and then installing into my TrueNas box.
Gk2011
#12 Post by Gk2011 » Mon Sep 22, 2025 11:23 pm
Gk2011 wrote: Mon Sep 22, 2025 5:29 am I guess I'll try flashing my drive down to the older firmware for my BU40N 1.03v
https://i.postimg.cc/tJnbtWdh/Screensho ... 191243.png
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_11:0'
Attempted to fix by downgrading to the 1.0 Firmware. No luck. Think I am going to just throw in the towel on having the 4k Ripper in the NAS Box and buy an enclosure for it on the desktop. I seem to still be able to pull blu-rays ok on TrueNAS. Just would of been nice for workflow to be able to dump everything onto the NAS and work back from there.
Gk2011
#13 Post by Gk2011 » Sat Oct 04, 2025 9:29 pm
Gk2011 wrote: Mon Sep 22, 2025 11:23 pm
If anyone comes along to this issue, I solved it by having only the container device exposed to makemkv and not the device name.
In my case it was
Device name: /dev/sr0
Device Container: /dev/sg4
I made an educated guess on this from the makemkv container github calling out that "Not exposing the Device name may cause performance issues". In my case I was already exposing it and the TrueNAS app forces you to input both. I converted it to a custom app to get just the YAML.
In the section for device change
- /dev/sr0:/dev/sg4
to
- /dev/sg4
No I do not know why this worked. When checking in the shell with lsscsi -g the drive shows as /dev/sr0 /dev/sg4.
Tried this after a second drive had this same issue. Can now open and rip UHD after making this change.
Gl everyone
