Backup erroring out
assemblerhead
Backup erroring out
Post by assemblerhead »
Getting this error on the last dvd in the set. MakeMKV worked on all the others.
MakeMKV v1.17.9 linux(x64-release) started
Debug logging enabled, log will be saved as /home/corbin/MakeMKV_log.txt
Backing up disc into folder "/home/corbin/Videos/backup/SG1_V5_R1_YR3.iso"
DEBUG: Code 100864261 at x&F`,Dz}fU9:($$\t':213132445
DEBUG: Code 100864261 at x&F`,Dz}fU9:($$\t':121262302
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'DVD+R-DL ATAPI iHAS424 B GL1B 3743524253 328217500745' at offset '0'
DEBUG: Code 2 at "v9&{UINE\@$28:29400232
DEBUG: Code 2 at "v9&{UINE\@$28:29393631
DEBUG: Code 0 at _L,|6aS=T3>b0\F_D:121263245
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
DEBUG: Code 3 at "v9&{UINE\@$28:29400232
DEBUG: Code 3 at "v9&{UINE\@$28:29393631
DEBUG: Code 100864261 at x&F`,Dz}fU9:($$\t':121263429
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'DVD+R-DL ATAPI iHAS424 B GL1B 3743524253 328217500745' at offset '6311878656'
DEBUG: Code 1 at H0B{srR)/k' :=4@2a3.P b:29395586
DEBUG: Code 3081972 at H0B{srR)/k' :=4@2a3.P b:213131939
DEBUG: Code 328 at :YUs/!22jeo.!"P\Q'Je:213133250
DEBUG: Code 16777216 at :YUs/!22jeo.!"P\Q'Je:121265062
DEBUG: Code 0 at :YUs/!22jeo.!"P\Q'Je:29394689
Running on Devuan linux.
Re: Backup erroring out
Errors like this:
indicate that the drive is having trouble reading a spot on the disc. The standard advice is to gently clean the disc and try again.
