Check which version of MakeMKV is installed
adave
Post by adave »
I'm running MakeMKV on a minimal Ubuntu Linux install and don't have a GUI. Is there a way I can check to see what version (i.e. 1.5.4) of MakeMKV my system is running from the terminal? Thanks.
crowfax
Re: Check which version of MakeMKV is installed
Post by crowfax »
makemkvcon info should do it.
matthew@loki:~$ makemkvcon info
MakeMKV v1.5.5 beta linux(x86-release) started
zipsick
Post by zipsick »
I have the same question. How can i find out what version of makemkv I have and how can I get a updated version if needed. I did not understand the 1 reply to this original question and need it answered again please.
zipsick wrote:
Tue Feb 18, 2025 11:39 pm
If you launch the MakeMKV GUI on any platform, it prints the version of MakeMKV on the first line of the log at the bottom of the window.
