MacOS Sequoia SCSI errors
Mike_Copy_Di
Post by Mike_Copy_Di » Sun Oct 27, 2024 6:02 pm
Trying to copy a UHD disk from PIONEER External Blu-ray Drive BDR-X13U-S
This worked before the OS upgrade
Tried multiple disks.
Getting the same errors
MakeMKV v1.17.8 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/mike/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-X13U 1.04 DDDL300587UCd" opened in OS access mode.
Backing up disc into folder "/Users/mike/Desktop/4AppleTV_Media/backup/LAST STARFIGHTER UHD"
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 0 at IE@e\g%ui]>#If+w>:213130766
DEBUG: Code 0 at J^Jv4gi[_Q'uS>V8o}:213131709
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 0 at J^Jv4gi[_Q'uS>V8o}:213131686
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 1 at J^Jv4gi[_Q'uS>V8o}:213131709
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/4F322CFF'
DEBUG: Code 1 at J^Jv4gi[_Q'uS>V8o}:213131686
rubicon0630
Re: MacOS Sequoia SCSI errors
Post by rubicon0630 » Tue Feb 18, 2025 11:56 pm
Any change you figured this one out. I'm getting the same errors. External Drive. Mine is a powered one so the power issue is not it. I can unplug the unit from my Mac and plug it in my PC and it works just fine. I'm running 15.3.1 so we are up to date. I thought it might be the enclosure but I bought a new one and same thing. Different USB cables and ports no help.
Post by dcoke22 » Wed Feb 19, 2025 1:07 am
rubicon0630 wrote: Tue Feb 18, 2025 11:56 pm I'm running 15.3.1 so we are up to date.
Perhaps this was just a simple type-o, but the current version of MakeMKV 1.17.9.
https://makemkv.com/download/
Mike_Copy_Di
Post by Mike_Copy_Di » Wed Feb 19, 2025 5:43 am
i gave up.
Purchased a drive from a poster on this forum.
Works perfectly
