Pioneer BDR-212EBK UHD support
liquidacid
Post by liquidacid » Sat Feb 08, 2025 11:36 pm
long time MakeMKV user here (license must be now over 10 years old).
I'm currently using two 5.25 inch drives in my server to rip optical media. One is a LG drive, the other one is a Pioneer drive. I recently added the first UHD media to my collection and encountered some problems while ripping.
The LG drive rips the discs fine, but the Pioneer doesn't even detect the discs. Hence I rule out a problem with the media itself.
The drive was purchased here in Germany as a Pioneer BDR-212EBK. According to the Pioneer product page the drive is at least BDXL compatible. I'm aware that this doesn't automatically imply UHD capability. I'm not finding good conclusive information that either confirms this (that UHD should be supported) or denies this, so I'm asking here.
MakeMKV drive information:
OS device name: /dev/sr1
Manufacturer: PIONEER
Product: BD-RW BDR-212M
Revision: 1.02
Serial number: <REMOVED>
Firmware date: 2022-03-09
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.02/ID56
sdftool output:
$ makemkvcon f --drive=dev_21:1 --info
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:RS8F00
8015:Firmware name
:PIONEER BDR-212T
8002:Firmware type
8106:Original (unpatched)
8003:Firmware version
:1.02/ID56
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:01.0
:DDCB943EDED5
Identification SDF present
8013:Status
8001:Drive platform
:Pioneer RS8F00
:ID56
pioneer:SAT :8F00:ID56: :PIONEER :BD-RW BDR-212M1.02: 22/03/09 :-
I know that Pioneer has a newer firmware (1.05) on their website. But according to information I found newer firmware is most likely removing LibreDrive functionality altogether without any way of bringing it back. So I'm not planning on going down that road at the moment.
With best wishes,
liquid
Re: Pioneer BDR-212EBK UHD support
Post by dcoke22 » Wed Feb 12, 2025 4:29 pm
I don't know if your Pioneer needs to be or can be cross flashed to support UHD. However, the person to talk to on this forum about it is Billycar11. You can find his email address in his signature on posts here or over at his seller page: https://forum.makemkv.com/forum/viewtopic.php?f=20&t=17831
Yethidran
Post by Yethidran » Wed Feb 12, 2025 4:57 pm
you are in luck buddy, because your pioneer drive firmware is before the "Dreaded firmware lock" done by the stupid brainless Pioneer Management.
get in touch with Billycar11 or Martymcnuts or Coopervid.
they can "Liberate" your Pioneer drive to be "LibreEnabled" to read and rip 4K uhd discs.
liquidacid
Post by liquidacid » Tue Feb 18, 2025 10:44 am
Thanks for the replies. I contacted Billy, but his tooling seems to be Windows-only. Which does not help here, since all my optical drives are connected to a Linux headless system.
Any other ideas? It seems strange to me that this whole stuff is Windows-only, in particular because sdftool operates flawlessly on native Linux.
Post by MartyMcNuts » Tue Feb 18, 2025 9:55 pm
liquidacid wrote: Tue Feb 18, 2025 10:44 am Thanks for the replies. I contacted Billy, but his tooling seems to be Windows-only. Which does not help here, since all my optical drives are connected to a Linux headless system.
Pioneer flashing tool is Windows only and has nothing to do with MakeMKV.
Just temporarily connect them to a Windows machine.
liquidacid
Post by liquidacid » Wed Feb 19, 2025 12:32 am
I got rid of my last Windows system like 10 years ago. So that really isn't an option.
Like I said, the drive is in a headless system. I.e. it has no display. I access the drives via iSCSI over local network. I would need to setup a Windows VM on this machine and passthrough the iSCSI target. Which I have no idea if that could even work. Or buy some USB enclosure for the drive and then deal with the all the trouble that comes with USB-SATA bridge chips.
That sounds like a lot of trouble with uncertain outcome. If this whole Pioneer firmware business is so Windows centric, then the lesson for me is: Don't buy a Pioneer device again.
Anyway, thanks to everyone for their input.
Post by MartyMcNuts » Wed Feb 19, 2025 1:54 am
liquidacid wrote: Wed Feb 19, 2025 12:32 am I got rid of my last Windows system like 10 years ago. So that really isn't an option.
That's because the majority of people still use Windows. The tool was made for Windows only.
Don't you have any friends/family that have a Windows PC or laptop?
liquidacid
Post by liquidacid » Wed Feb 19, 2025 8:24 am
No, most of the people here have moved away from Windows. In particular after the ridiculous HW requirements that Windows 11 has. I could probably find someone who still has a laptop with a Windows 8.1 installation. But then I again need an USB enclosure. And I'm not willing to buy additional stuff just for this.
Guess I'm going to ask on CDRInfo.pl for access to this BDRFlash utility (which works with Wine according to my sources).
Post by Coopervid » Wed Feb 19, 2025 11:30 am
It's the identical thing.
flojo
Post by flojo » Wed Feb 19, 2025 12:53 pm
I flashed in VMWare just fine.
Download Windows 10 from here: https://www.microsoft.com/en-gb/softwar ... ndows10ISO
Download VMWare from here (you need a free account): https://support.broadcom.com/group/ecx/ ... tation+Pro
You can try Virtualbox instead of VMWare, but at the time I had a problem with passing the drive through.
