neo14
Post
by neo14 » Mon Feb 17, 2025 6:18 pm
zittrig wrote: ↑Mon Feb 17, 2025 4:43 pm
Perhaps overseen.
Your drive is flashable. Flash directly to LG WH16NS60 1.02MK (no sleep bug) or ASUS 3.10MK (with sleep bug).
You'll find all information you need in the first post of this topic. Try it.
no problem
I saw all the information and I think I have no problem flashing it, but I would rather ask before getting a brick
but you said I can put the LG version, this is something new for me, and in the end it seems to be a better option than the Asus version (with the suspension bug) so I will try the LG version.
Thanks a lot
zittrig
Post
by zittrig » Mon Feb 17, 2025 6:49 pm
In this ASUS works a LG drive, ASUS is "only" a OEM manufacturer, so you can flash the WH16NS60 1.02MK without problems.
uhdarty
Post
by uhdarty » Mon Feb 17, 2025 8:56 pm
zittrig wrote: ↑Mon Feb 10, 2025 8:35 pm
Show your MakeMKV drive information.
But I think you can flash directly to WH16NS60 1.02MK.
Edit:
Sorry I've read your model wrong. Of course is the BH16NS40 with NS51 flashable.
You don't need a firmware backup. With the original LG firmware auto updater you can get your drive back to 1.05.
thank you so much
I still made a dump, not sure it it worth anything but still....
then flashed HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin and ... bamm, I have an UHD friendly drive!
although now I recognized makemkv is shareware only and its price is quite high so not sure what to do now... (not that devs do not deserve all the money! they do). I only have a single UHD disc (any many BD and DVD), but wanted something "futureproof"......
neo14
Post
by neo14 » Mon Feb 17, 2025 9:24 pm
zittrig wrote: ↑Mon Feb 17, 2025 6:49 pm
It worked perfect
thanks a lot!!!
fozzmoo
Post
by fozzmoo » Tue Feb 18, 2025 4:32 am
Howdy. I'm running Linux and I have a HL-DT-ST BD-RE WH14NS40, SVC CODE of NS50 running firmware version 1.05. I understand from the first page post this is an encrypted firmware so I need to run 'makemkvcon' with the 'enc' option. However, I'm confused what firmware I should be installing on it to be able to read UHD discs. I've tried unsuccessfully to flash it with HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin. When I run the makemkvcon command, it just sits there and does nothing.
zittrig
Post
by zittrig » Tue Feb 18, 2025 4:33 am
uhdarty wrote: ↑Mon Feb 17, 2025 8:56 pm
Edit:
My thoughts in the past were what costs a full MakeMKV license to watch my 4k discs on my PC supported "home cinema" and what will cost an UHD player completely with a new digital sound system to change it with my analogue one 7.1 THX.
Only 60 €, in my case, were more than future proof.
zittrig on Tue Feb 18, 2025 4:36 am, edited 1 time in total.
Mr_Orange
Post
by Mr_Orange » Tue Feb 18, 2025 4:36 am
Edit:
thank you so much
BD (and DVD) ripping is all part of the software. The licence isn't just for UHDs it's for all 3 formats.
DrakkerFlight
Post
by DrakkerFlight » Wed Feb 19, 2025 4:08 am
Hi, thank you for the guide. I am trying to flash the BP60NB10 LG Slim drive. It looks like it was successfully flashed and shows firmware version as 1.02 in MakeMKV, however, when I attempt to open a UHD blu ray I get the following errors
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/559B8F9D'
Do you have any guidance on what the issue may be?
Post
by dcoke22 » Wed Feb 19, 2025 5:07 am
DrakkerFlight wrote: ↑Wed Feb 19, 2025 4:08 am
What does MakeMKV show for the details of your drive? Post all that info from the first screen in MakeMKV here.
shinkiro
Post
by shinkiro » Wed Feb 19, 2025 6:48 am
Hi guys, I just got the Buffalo Japanese drive "BRUHD-PU3" (external) but I don't know which tool or firmware to use to read UHD blu-ray discs.
Do I use the flasher on this thread: viewtopic.php?f=16&t=22896 or something else entirely?
I saw that "MartyMcNuts" said to use "1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
2. DE_Buffalo_BRUHD-PU3_BU10 OR DE_LG_BU40N_1.00", so any of these three firmwares work?
dirtygarbageman
Post
by dirtygarbageman » Wed Feb 19, 2025 10:01 pm
Thanks for posting all of this. I had some issues understanding the instructions with makeMKV in a snap on Ubuntu, so I ran the GUI on Windows and it was a breeze for an "archgon Premium Aluminum External USB 3.0 UHD 4K Blu-Ray Writer Super Drive for PC and Mac" that identifies as BD-RE BU40N.
DrakkerFlight
Post
by DrakkerFlight » Thu Feb 20, 2025 12:43 am
This is what MakeMKV shows for my drive
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM04OBKC5309
Firmware date: 2121-07-08 15:56
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Post
by dcoke22 » Thu Feb 20, 2025 3:00 am
DrakkerFlight wrote: ↑Thu Feb 20, 2025 12:43 am
Revision: 1.02
I don't think your drive is properly flashed. If it was, for Status it would say 'Enabled'.
DrakkerFlight
Post
by DrakkerFlight » Thu Feb 20, 2025 3:37 am
I appreciate your quick replies and help. I tried refreshing multiple times. Each time it says the flash is successful but the Status hasn't changed to enable. Below is what the terminal output looks like (This is on a Mac mini M2). I followed the Mac flashing command instructions under the "How To Flash Videos and commands:" section on this guide.
Do I need to revert back to the original firmware (not sure where to get the from) before attempting to flash back?
MacOS % ./makemkvcon f -d '/IOBDServices/2D033E1B' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Reading input file /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Current Drive ID: HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM04OBKC5309
Using USB chipset workaround for Desktop drive handshake
yes
100% Operation finished
Done successfully
zittrig
Post
by zittrig » Thu Feb 20, 2025 4:18 am
shinkiro wrote: ↑Wed Feb 19, 2025 6:48 am
Show drive information with MakeMKV.
