Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
uhdarty
#2731 Post by uhdarty » Mon Feb 17, 2025 8:56 pm
zittrig wrote: Mon Feb 10, 2025 8:35 pm Show your MakeMKV drive information.
But I think you can flash directly to WH16NS60 1.02MK.
Edit:
Sorry I've read your model wrong. Of course is the BH16NS40 with NS51 flashable.
You don't need a firmware backup. With the original LG firmware auto updater you can get your drive back to 1.05.
thank you so much :) I still made a dump, not sure it it worth anything but still....
then flashed HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin and ... bamm, I have an UHD friendly drive!
although now I recognized makemkv is shareware only and its price is quite high so not sure what to do now... (not that devs do not deserve all the money! they do). I only have a single UHD disc (any many BD and DVD), but wanted something "futureproof"......
neo14
#2732 Post by neo14 » Mon Feb 17, 2025 9:24 pm
zittrig wrote: Mon Feb 17, 2025 6:49 pm In this ASUS works a LG drive, ASUS is "only" a OEM manufacturer, so you can flash the WH16NS60 1.02MK without problems.
It worked perfect :) thanks a lot!!!
fozzmoo
#2733 Post by fozzmoo » Tue Feb 18, 2025 4:32 am
Howdy. I'm running Linux and I have a HL-DT-ST BD-RE WH14NS40, SVC CODE of NS50 running firmware version 1.05. I understand from the first page post this is an encrypted firmware so I need to run 'makemkvcon' with the 'enc' option. However, I'm confused what firmware I should be installing on it to be able to read UHD discs. I've tried unsuccessfully to flash it with HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin. When I run the makemkvcon command, it just sits there and does nothing.
zittrig
#2734 Post by zittrig » Tue Feb 18, 2025 4:33 am
uhdarty wrote: Mon Feb 17, 2025 8:56 pm
Edit:
My thoughts in the past were what costs a full MakeMKV license to watch my 4k discs on my PC supported "home cinema" and what will cost an UHD player completely with a new digital sound system to change it with my analogue one 7.1 THX.
Only 60 €, in my case, were more than future proof.
Mr_Orange
#2735 Post by Mr_Orange » Tue Feb 18, 2025 4:36 am
Edit:
BD (and DVD) ripping is all part of the software. The licence isn't just for UHDs it's for all 3 formats.
DrakkerFlight
#2736 Post by DrakkerFlight » Wed Feb 19, 2025 4:08 am
Hi, thank you for the guide. I am trying to flash the BP60NB10 LG Slim drive. It looks like it was successfully flashed and shows firmware version as 1.02 in MakeMKV, however, when I attempt to open a UHD blu ray I get the following errors
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/559B8F9D'
Do you have any guidance on what the issue may be?
#2737 Post by dcoke22 » Wed Feb 19, 2025 5:07 am
DrakkerFlight wrote: Wed Feb 19, 2025 4:08 am Hi, thank you for the guide. I am trying to flash the BP60NB10 LG Slim drive. It looks like it was successfully flashed and shows firmware version as 1.02 in MakeMKV, however, when I attempt to open a UHD blu ray I get the following errors
What does MakeMKV show for the details of your drive? Post all that info from the first screen in MakeMKV here.
shinkiro
#2738 Post by shinkiro » Wed Feb 19, 2025 6:48 am
Hi guys, I just got the Buffalo Japanese drive "BRUHD-PU3" (external) but I don't know which tool or firmware to use to read UHD blu-ray discs.
Do I use the flasher on this thread: viewtopic.php?f=16&t=22896 or something else entirely?
I saw that "MartyMcNuts" said to use "1. HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922.bin
2. DE_Buffalo_BRUHD-PU3_BU10 OR DE_LG_BU40N_1.00", so any of these three firmwares work?
dirtygarbageman
#2739 Post by dirtygarbageman » Wed Feb 19, 2025 10:01 pm
Thanks for posting all of this. I had some issues understanding the instructions with makeMKV in a snap on Ubuntu, so I ran the GUI on Windows and it was a breeze for an "archgon Premium Aluminum External USB 3.0 UHD 4K Blu-Ray Writer Super Drive for PC and Mac" that identifies as BD-RE BU40N.
DrakkerFlight
#2740 Post by DrakkerFlight » Thu Feb 20, 2025 12:43 am
This is what MakeMKV shows for my drive
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM04OBKC5309
Firmware date: 2121-07-08 15:56
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.02
#2741 Post by dcoke22 » Thu Feb 20, 2025 3:00 am
DrakkerFlight wrote: Thu Feb 20, 2025 12:43 am This is what MakeMKV shows for my drive
Revision: 1.02
I don't think your drive is properly flashed. If it was, for Status it would say 'Enabled'.
DrakkerFlight
#2742 Post by DrakkerFlight » Thu Feb 20, 2025 3:37 am
I appreciate your quick replies and help. I tried refreshing multiple times. Each time it says the flash is successful but the Status hasn't changed to enable. Below is what the terminal output looks like (This is on a Mac mini M2). I followed the Mac flashing command instructions under the "How To Flash Videos and commands:" section on this guide.
Do I need to revert back to the original firmware (not sure where to get the from) before attempting to flash back?
MacOS % ./makemkvcon f -d '/IOBDServices/2D033E1B' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Reading input file /tmp/HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
Current Drive ID: HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM04OBKC5309
Using USB chipset workaround for Desktop drive handshake
yes
 100% Operation finished
Done successfully
zittrig
#2743 Post by zittrig » Thu Feb 20, 2025 4:18 am
shinkiro wrote: Wed Feb 19, 2025 6:48 am Hi guys, I just got the Buffalo Japanese drive "BRUHD-PU3" (external) but I don't know which tool or firmware to use to read UHD blu-ray discs.
Show drive information with MakeMKV.
#2744 Post by Billycar11 » Thu Feb 20, 2025 4:47 am
DrakkerFlight wrote: Thu Feb 20, 2025 3:37 am I appreciate your quick replies and help. I tried refreshing multiple times. Each time it says the flash is successful but the Status hasn't changed to enable. Below is what the terminal output looks like (This is on a Mac mini M2). I followed the Mac flashing command instructions under the "How To Flash Videos and commands:" section on this guide.
yes
Done successfully
you forgot enc
cf1084
#2745 Post by cf1084 » Thu Feb 20, 2025 4:51 am
I bought this unit and was able to record a UHD BD (so it says on the box), but I tried other movies and it doesn't read them... what can I do?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-213M
Revision: 1.05
Serial number: ****
Firmware date: 2023-08-01
Highest AACS version: 68
Drive platform: Pioneer RS9200
Firmware version: ID56
