geminikanon
Re: SDFtool Flasher
Post by geminikanon » Fri Feb 14, 2025 6:57 am
I have the same situation, unit not open tray & not read discs, I followed the instructions
My unit is BP50NB40 SVC CODE: NS50
Help please :(
ryley
Re: SDFtool Flasher
Post by ryley » Fri Feb 14, 2025 7:06 am
MartyMcNuts wrote: Fri Feb 14, 2025 6:25 am I have no idea what steps you are following but they are not the right one's! It looks like you have flashed a very old firmware to your drive. Nowhere do any instructions mention flashing BP50NB40 1.00 firmware to the drive!!
The correct procedure is provided in detail in the first post of this very thread.
I think xxpickles may have skipped to the very end of your first post and missed a few important details:
MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am Hi everyone,
I have created a windows GUI for the MakeMKV sdftool command line flasher. The appearance (and use) is similar to the modifed ASUS flasher, which should make it a bit easier for those that are unsure about using the command line. The latest version is v1.3.5.
PS: For your convenience, here are the firmware files to recover the old LG/ASUS drives:
DE_LG_WH16NS40_1.01.bin.zip
DE_ASUS_BW-16D1HT_1.01.bin.zip
BP50NB40-NB40 1.00 viewtopic.php?p=129930#p129930
Enjoy!! 8)
xxpickles
Re: SDFtool Flasher
Post by xxpickles » Fri Feb 14, 2025 3:05 pm
It was a separate thread that was specific to the drive I have. Looking at it now, it was also using an older version of the SDFlasher program and a couple of years old at this point.
I went back through the instructions and tried again. The drive opens and attempts to read the UHD disc, but it still shows that there is no disc. It did read a Blu-ray disc with no issues.
OS device name: H:
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: ***********************
Firmware date: 2120-05-07 09:29
Highest AACS version: 81
Firmware version: 1.03
Re: SDFtool Flasher
Post by Billycar11 » Fri Feb 14, 2025 8:10 pm
xxpickles wrote: Fri Feb 14, 2025 3:05 pm
OS device name: H:
Revision: 1.03
You have to be on bp60 fw or bu40n see guide for flashing sequence below
xxpickles
Re: SDFtool Flasher
Post by xxpickles » Fri Feb 14, 2025 9:24 pm
Billycar11 wrote: Fri Feb 14, 2025 8:10 pm You have to be on bp60 fw or bu40n see guide for flashing sequence below
Got it. I think that's the step that originally got me into the problem with the really old version. I did get it flashed with the correct version, and I'm currently ripping "True Lies" as a test.
Thanks for the assistance!
geminikanon
Re: SDFtool Flasher
Post by geminikanon » Sat Feb 15, 2025 7:31 am
How can I make that my unit read UHD discs? I have already followed the steps as indicated in the guide.
the flashing is done and the firmware is changed but the unit is left in a state where the tray does not open,
I must restore it with the firmware BP50NB40-NB40-1.00-Clean.bin to make it work again.
I try to update with the official application, it show a message that the SVC code is different and does not allow me.
Any help or suggestions would be greatly appreciated.
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Feb 15, 2025 10:54 pm
geminikanon wrote: Sat Feb 15, 2025 7:31 am How can I make that my unit read UHD discs? I have already followed the steps as indicated in the guide.
Why are you using that old flasher from years ago?? I'm not sure what instructions you are following but they must be very old for yhou to be using that.
Why not follow the instrucitons in the first post of this very thread??
geminikanon
Re: SDFtool Flasher
Post by geminikanon » Sun Feb 16, 2025 7:28 am
MartyMcNuts wrote: Sat Feb 15, 2025 10:54 pm
I followed the instructions step by step using SDFtool flasher v1.3.5, and only get that my unit remain unusable, the tray don't open
Re: SDFtool Flasher
Post by MartyMcNuts » Mon Feb 17, 2025 1:53 am
geminikanon wrote: Sun Feb 16, 2025 7:28 am
You have to use the RECOVERY option as you have flashed it with old firmware. You should have never touched the BP50NB40-NB40-1.00-Clean.bin firmware as that is for people that accidently flashed old pre October 2015 drives.
beancounter
Newbie failing to flash WP50NB40
Post by beancounter » Mon Feb 17, 2025 11:55 pm
Hello. Senior newbie having trouble with flashing my new WP50NB40 drive. Tried to flash it. No luck.
Tried to follow instructions to repair in other messages, no luck. Here is where my drive is now:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number:
The drive opens, but does not recognize my 4k copy of North By Northwest.
Please have pity on this old man trying to get a Plex server populated. Thanks so much.
Re: Newbie failing to flash WP50NB40
Post by MartyMcNuts » Tue Feb 18, 2025 12:10 am
beancounter wrote: Mon Feb 17, 2025 11:55 pm Hello. Senior newbie having trouble with flashing my new WP50NB40 drive. Tried to flash it. No luck.
Revision: 1.03
Serial number:
You have only done the first flash. Now you need to finish with the cross-flash.
1. Select drive
2. Select RECOVERY
3. In popup window choose the firmware that is currently on the drive (in your case, BP50NB40 1.03-MK)
4. In firmware selection drop down box select DE_LG_BU40N_1.00 firmware
5. Click START and the process should be done after about 30 seconds or so.
beancounter
Re: SDFtool Flasher
Post by beancounter » Tue Feb 18, 2025 3:12 am
Mr McNuts - I thank you very much. My drive is whirring away ripping NxNW as I type. A testament to a community with helpful people. Much appreciated...
Greenleaf
Re: SDFtool Flasher
Post by Greenleaf » Fri Feb 21, 2025 6:49 am
I just wanted to thank you for this tool. I was able to flash my Asus BW-16D1X-U that I bought on 02-17-25. It came with firmware revision A105. I was able to flash it to revision 3.10.
Here is a link to the unit I bought
BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK
I went with the Asus .bin file from the "all you need firmware pack" -> ASUS-BW-16D1HT-3.10-WM01601-211901041014
Your awesome tool
Also, thank you for the visual aid (GIF) you provided for us. It was very helpful for a dummy like me haha :lol:
Thank you!
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Feb 21, 2025 10:27 pm
Greenleaf wrote: Fri Feb 21, 2025 6:49 am Hello,
Your awesome tool
Thank you!
You're welcome!
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Feb 21, 2025 10:29 pm
beancounter wrote: Tue Feb 18, 2025 3:12 am Mr McNuts - I thank you very much. My drive is whirring away ripping NxNW as I type. A testament to a community with helpful people. Much appreciated...
You're welcome!!
