DUMP Submitted Mandalorian S3
MKB20_v77_The_Mandalorian-_Season_3_Disc_1_D61A : 043674A897095B25DE9FE805F24FAB810E57BB07
MKB20_v77_The_Mandalorian-_Season_3_Disc_2_A496 : E68415D9656A82CC0FD6039D47CB81B798C39A79
keydb_helper
Re: DUMP Submitted Mandalorian S3
The D61A and A496 Mandalorian season 3 discs have been added to the public keydb
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Confirmed working. Thanks!
MKB20_v77_The_Mandalorian-_Season_3_Disc_2_03BE
phantomapollyon
Disc 1 for me worked using the public DB, but Disc 2 did not. (submitted the dumps of course)
Dump files submitted.
They're not in the KEYDB. I was unable to find the unit keys. I know they were created on Pioneer drives so I'm not sure if someone can process them or not for the KEYDB.
These dump files is created on an ASUS drive
Sorry, yes looking at the wrong thing. Yea, hopefully someone will be able to add them.
keydb_helper
The 3796 and 48F4 Mandalorian discs have been added to the public keydb
Thank you!keydb_helper wrote: ↑Tue Feb 18, 2025 12:13 am
bobbyhugepike
Hello everyone,
I've added two dump files, created with a Pioneer BDR-12EBK (BD-RW BDR-S12U flashed for UHD).
The last KEYDB.cfg doesn't work.
bobbyhugepike
Thanks a lot for the quick fix.
The updated KEYDB file works now with Pioneer drives.
