mm13579
Post by mm13579 » Sun Feb 16, 2025 12:43 pm
I am just trying to get it to work again as I stated in same PC setup it worked 1 year ago for dvd, Blu ray, UHD. This week nothing worked so I tried flashing it to 1.03, 1.02, 1.01, 1.00 and it said loading disc and it said no disc found in makemkv. I followed the guide in this forum for 1.03mk and it is now working for dvd and Blu ray again. But the issue is I still can't get it to recognize UHD discs as it spins them says loading then disc not found.
So I don't know if I am missing something or if another firmware is needed to make everything work correctly again?
neo14
Post by neo14 » Sun Feb 16, 2025 1:24 pm
I have never flashed any Blu ray optical drive, and I don't want to get a brick, so I prefere to ask before do it. I saw some videos to do it and It seems easy to do it, but can I do It in my optical drive? The model is Asus BW-16D1HT, and the information makemkv give me is this:
Información de unidad de disco
Nombre del SO del dispositivo: D:
Fabricante: ASUS
Producto: BW-16D1HT
Revisión: 3.11
Número de serie: ...
Fecha del firmware: 2120-12-01 17:59
Marcas de cifrado bus: 1F
Highest AACS version: 77
Do I need to check another thing before flash it? The optical drive is from Augost of 2023. When I open sdftool, there are two sticks in green in MT1959 and encrypted firmware.
I think I can do it with any problem but I would like to be sure to do it.
trooperdadon87
Post by trooperdadon87 » Sun Feb 16, 2025 1:38 pm
d00zah wrote:
Sat Feb 15, 2025 6:08 pm
trooperdadon87 wrote:
Sat Feb 15, 2025 4:14 pm
can someone help me? was it working or still 1.02 ? i dont know why there shows still 1.02 when i open makemkv ?
here is the information:
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Try the SDFtool Flasher & the same FW ( HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin ).
thanks doozah !
i think now it works.
"Status: Enabled
Firmware version: 1.03
Unrestricted read speed: Yes"
is this now enough to do to read and copy uhd discs or do i have to do something else becaue of some bugs or something?
Post by d00zah » Sun Feb 16, 2025 1:44 pm
Read the UHD FAQ to begin. And occasionally skim the forum... MUCH useful info here, if one takes time to look.
trooperdadon87
Post by trooperdadon87 » Sun Feb 16, 2025 2:01 pm
i mean in the guide there is written:
Sleep Bug:
All UHD Friendly drives have the sleep bug, this is when a UHD disk is left idle in the drive for 2 minutes. Once the drive goes to sleep, the UHD Friendly drive will no longer be able to read the disk without opening and closing the disk tray and will make horrible seeking noises until this is done.
Sleep Bug Fix:
To fix the sleep bug on a UHD Friendly drive flash firmware from an UHD Official drive like WH16NS60 DE 1.00 or 1.01MK 1.02MK 1.03MK
can i ignore this with the patched version 1.03 or do i have to fix?
Post by d00zah » Sun Feb 16, 2025 2:13 pm
To the best of my knowledge, the sleep bug is not present in slim drives. Mostly an annoyance, but if you happen to leave a disc in an idle drive...
And...
Crossflashing Warnings:
1. Don't crossflash desktop drives to slim drives or the other way around
2. ...
trooperdadon87
Post by trooperdadon87 » Sun Feb 16, 2025 3:21 pm
ok so i dont have to do anything, right?
i dont understand whats crossflashing ? and for what i use/need it?
Post by d00zah » Sun Feb 16, 2025 3:31 pm
You are good to go. Enjoy!
Post by MartyMcNuts » Mon Feb 17, 2025 2:07 am
Sleep Bug:
Sleep Bug Fix:
That is for friendly drives. The BU40N is an official drive, thus no sleep bug. Also, it only effects desktop drives anyway, not slim drives.
zittrig
Post by zittrig » Mon Feb 17, 2025 7:00 am
First post in this topic says among other things:
"Crossflashing:
1. Changes the drive to act as another and gain most or all of its benefits
2. Can be used to increase a drives ripping speed and fix the sleep bug
2. In some cases crossflashing an Asus drive to an LG or the other way around you may no longer be able to burn disks-SamuriHL
3. Flashing Official UHD firmware to a UHD Friendly drive will not enable Powerdvd aacs 2 decryption or playback"
zittrig
Post by zittrig » Mon Feb 17, 2025 7:01 am
Crossflashing:
neo14
Post by neo14 » Mon Feb 17, 2025 10:28 am
Nobody can help me with my question above? Thanks
zittrig
Post by zittrig » Mon Feb 17, 2025 4:43 pm
Perhaps overseen. 😉
Your drive is flashable. Flash directly to LG WH16NS60 1.02MK (no sleep bug) or ASUS 3.10MK (with sleep bug).
You'll find all information you need in the first post of this topic. Try it. 👋
neo14
Post by neo14 » Mon Feb 17, 2025 6:18 pm
Perhaps overseen. 😉
no problem :) I saw all the information and I think I have no problem flashing it, but I would rather ask before getting a brick :D but you said I can put the LG version, this is something new for me, and in the end it seems to be a better option than the Asus version (with the suspension bug) so I will try the LG version.
Thanks a lot
zittrig
Post by zittrig » Mon Feb 17, 2025 6:49 pm
In this ASUS works a LG drive, ASUS is "only" a OEM manufacturer, so you can flash the WH16NS60 1.02MK without problems.
