Subtitles for Dummies, or At Least Newbies
AVGeek99
I'm about two weeks in ripping my 4K Blu Ray collection. I'm putting my movies on a Synology NAS, which is where my Plex Media Server is running. My primary Plex playback client is a 2019 nVidia Shield Pro. All I have been using is makeMKV ripping to .mkv files and placing them on my NAS. I'm not using handbrake, MKVToolNix or any other tool I've seen referenced in my searching. I'm not familiar with any of them, but I can learn if necessary.
It took me about a week before I discovered you could open up the file tree and see what languages and subtitles were included, and then I discovered you could set a default language, which I had set do English. By default this unchecks all other languages, including subtitles, forced or otherwise. I ripped a few that way and now I'm all but certain I'm not getting foreign language subtitles.
All I'm really looking to know is what is the simplest surefire way to ensure I get foreign language subtitles (when they exist) while I am watching with the english audio and someone is speakign in a different language. Sometimes I get warning errors referencing an "AV Sync error at 00:00:00 in track xyz..." related to subtitles. It makes me think that subtitles are tied to the same language audio, but that is just my newbie speculation.
Am I ok to uncheck audio languages I don't want and then just leave all subtitles selected. Am I ok to only leave all "forced" subtitles selected, or should I just have all subtitles selected to be safe. Or am I better off just selecting all audio languages and subtitles?
Thank you.
Thank you.
Re: Subtitles for Dummies, or At Least Newbies
The answer is, "Maybe, could be!"
The only safe way to do things is to extract EVERY language track, and toss the ones you don't want out later. The reason? Disk authors suck at naming stuff and composing disks.
Forced subtitles can be tagged as forced within the main subtitle track, or just be a separate track, with nothing marked as forced. Some can be placed on the side of the speaker, most are centered in the frame. Sometimes, they have multiple tracks. They subtitle the audio commentary. Or ... ?
Subtitles are important to me - my main ripping is of anime.
Audio sync errors are usually information, as MakeMKV will usually correct the sync issues when they're less than a second.
AVGeek99
Thank you!! And how do you "toss out" language tracks you don't want after the .mkv has already been created?
Two ways. First is the long way, HANDBRAKE. Everything I do, goes through handbrake to shrink it. Anime typically shrinks 80-90%, because it isn't that complex. Movies, 50% is typical. But I can tweak out the audio and subtitle tracks at the same time. A typical rip will get converted (used to) have stereo English, 5.1 or better English, plus one or two tracks of Japanese. I've cut that to just 5.1 recently. I also choose which subtitle tracks to keep.
For those things I don't want to shrink, I'll just run mkvtoolnix to remove the tracks I don't want.
Handbrake takes time to run; mkvtoolnix moves pretty quickly, since it isn't re-encoding stuff.
(I cheat, though - I run it all as scripts, rather than using their GUIs)
AVGeek99
Thanks!! I want 1:1 bit copies, both audio and video, so no reencoding or compression. Looks like I need to get mkvtoolnix.
Thank you again!!
Thank you again!!
AVGeek99
I've installed mkvtoolnix, so now I can go back and strip out all of the language and subtitle tracks I don't need/want. It's pretty simple to use, at least to remove audio and subtitle tracks, which is all I've done so far.
But I have a question about subtitles. For subtitles all I want is English, removing others is easy enough. I have my Plex server configured ot autmatically display English subtitles when there is a non-english language being spoken. So obviously I want forced subtitles. But I've noticed when ripping movies in makemkv there are sometimes multiple english subtitle tracks, forced and unforced. When I'm in mkvtoolnix I see the english subtitle tracks, but none are flagged as forced. So in order to get the subtitles to display appropriately I need to mark one as flagged. Is there a simple way to identify which of the subtitle tracks should be marked as forced?
sterickson
Another tool to try, to get info about your MKV file, is MediaInfo. [Edited for typos.]
Bobbybob
You can use Subtitle Edit to take a look at the subtitles. Forced subtitles usually have very few texts (maybe 20 per movie).
Other subtitles you may find are subtitles for the full movie, subtitles for people with problems with hearing and subtitles for commentary etc. Sometimes there are also "comments" to the movie available as subtitles.
If you're not sure, you can find the timestamps of the Subtitles in Subtitle Edit and then you can check in the movie if it's what you want.
VarHD
On a side-note, if you want to know if a movie has separate subtitles for non-English parts, you can refer to this sheet: https://docs.google.com/spreadsheets/d/ ... =139821986
Chetwood
Play back the movie in VLC an enable a subtitle track. If someone is speaking and there's no subitle shown, it's most like the forced track.AVGeek99 wrote: Wed Feb 19, 2025 6:36 amIs there a simple way to identify which of the subtitle tracks should be marked as forced?
gentile2226
The simplest way is at the time of ripping the disc. My process is that if there is more than one subtitle track I open the disc in VLC, navigate the menus and disable any subtitles. Then I play the movie and check which subtitle track is enabled. If none then there isn't a dedicated forced subtitle track. If there is I note which track it is and mark that in MakeMKV as the forced subtitle. That only covers cases where there's a dedicated forced subtitle track.AVGeek99 wrote: Wed Feb 19, 2025 6:36 am I've installed mkvtoolnix, so now I can go back and strip out all of the language and subtitle tracks I don't need/want. It's pretty simple to use, at least to remove audio and subtitle tracks, which is all I've done so far.
For all other cases you can rely on MakeMKV in its default profile to extract and mark subtitle tracks as forced for you. For each English subtitle a video has (provided its a blu-ray) it should have a nested subtitle inside it. If MakeMKV detects that the forced subtitle track is empty then it will be discarded, if it has anything at all in it then it will be extracted and it will have the "Forced" flag configured automatically.
When it comes to already remuxed MKVs you just have to figure it out yourself using tips like the ones provided above however I also have another tip. If you install MediaInfo you can load the MKV in it, change it to HTML view and check the "count of elements" field to see how many pieces of text are in the subtitle tracks. If you find one has 2000 elements and one has 50, it's very likely that the one with 50 is the forced subtitle track you're looking for. Another rule of thumb is if you have one that is around 2000 and one that is 2500-3000, the larger one is probably the SDH (hard of hearing) track.
Hope this helps.
AVGeek99
Thank you for all the reponses, they have been very helpful. I am now using Subtitle Edit to identify the forced subtitles and then setting the flag using MKVToolNix.
Is there anyway to have MakeMKV set the forced flag upon ripping. Prior to ripping in the file tree it identifies forced subtitles, but after ripping I pull them into MKVToolNix and none of the subtitle tracks have the forced flag set. I have confirmed with a couple different movies, the subtitles only show when I select a subtitle track for playback. Am I doning something wrong in my ripping?
Thanks again!!
Thanks again!!
Yes. Highlight the subtitle track to be marked as forced. In the dropdown in the Properties box on the right, select MKV Flags. In the value field, put an 'f'. If you want to mark the track as default as well, put a 'd'.AVGeek99 wrote: Tue Feb 25, 2025 5:51 am Is there anyway to have MakeMKV set the forced flag upon ripping.
AVGeek99
Thank you!!! It took me a while to figure out what you were talking about, but it finally sunk in. Sometimes I'm slow.dcoke22 wrote: Tue Feb 25, 2025 6:01 amYes. Highlight the subtitle track to be marked as forced. In the dropdown in the Properties box on the right, select MKV Flags. In the value field, put an 'f'. If you want to mark the track as default as well, put a 'd'.AVGeek99 wrote: Tue Feb 25, 2025 5:51 am Is there anyway to have MakeMKV set the forced flag upon ripping.
And thank you all for your other pointers. For all the movies I've ripped without flagging the forced subtitles I now have Subtitle Edit which helps me identify the forced subtitles and then I use MKVToolNix to add the flag.
