Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
dizzycreator
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
#91 Post by dizzycreator » Sun Feb 16, 2025 8:53 pm
Yes, please send next PM.
dizzycreator
#92 Post by dizzycreator » Sun Feb 16, 2025 9:12 pm
Currently in the 43890's factory state I put in a 4K disc and it spins it a few times then spits it out. It reads HD discs, but spits out UHD/4K discs.
Info from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
zeemysteryman
#93 Post by zeemysteryman » Sun Feb 16, 2025 11:34 pm
I have the opportunity to go get one of these. As of now, are they still flashable for UHD?
dizzycreator
#94 Post by dizzycreator » Mon Feb 17, 2025 8:49 am
Just got the flash today and it worked first try. Thank you coopervid!!
I did the flash on a PC, but I'm using makemkv on a mac. Getting macos Sequoia to playback .mkv files properly with the HDR tone mapping to my display was a separate ordeal. I finally got it to work with Movist Pro.
megaturkey
#95 Post by megaturkey » Tue Feb 18, 2025 2:42 pm
Got my blu-ray collection backed up with this drive. All was well, but apparently, it won't work for 4K. Any help would be greatly appreciated if possible.
OS device name: G:
Revision: 1.11
Serial number:
Firmware date: 2018-11-28
Highest AACS version: 50
Firmware version: 1.11
spacegodzilla11
#97 Post by spacegodzilla11 » Thu Feb 20, 2025 1:19 am
enolagay
#98 Post by enolagay » Thu Feb 20, 2025 5:01 am
Would it be possible for you to send me a copy of this flasher? I picked up one of these drives and would love to get it reading UHD as well. Thanks!
Fox_Mulder
#99 Post by Fox_Mulder » Thu Feb 20, 2025 6:23 pm
Coopervid wrote: Fri Jan 10, 2025 2:18 pm
Fox_Mulder wrote: Fri Jan 10, 2025 2:10 am
Coopervid wrote: Thu Jan 09, 2025 9:25 pm
Post your Makemkv info.
How much should the firmware cost? I'm trying to decide which is more worthwhile.
I don't charge for it but you are free to send some bucks as appreciation.
I was now able to buy a 43890.
Laufwerksinformation
OS-Gerätename: J:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: **************
Firmware-Datum: 2020-06-15
Highest AACS version: 77
@Coopervid
I hope that the hardware is ok for firmware UD04?
Robo111
#100 Post by Robo111 » Fri Feb 21, 2025 7:48 am
Hi Coopervid, I have the Verbatim 43890 - that isn't reading 4k - can you help me please?
OS device name: H:
Revision: 1.14
Serial number:
#101 Post by Coopervid » Fri Feb 21, 2025 4:23 pm
Fox_Mulder wrote: Thu Feb 20, 2025 6:23 pm
OS-Gerätename: J:
Produzent: PIONEER
Revision: 1.14
@Coopervid
PM is coming.
#102 Post by Coopervid » Fri Feb 21, 2025 4:27 pm
Robo111 wrote: Fri Feb 21, 2025 7:48 am Hi Coopervid, I have the Verbatim 43890 - that isn't reading 4k - can you help me please?
OS device name: H:
Revision: 1.14
Serial number:
PM sent.
slickpic
#103 Post by slickpic » Fri Feb 21, 2025 6:13 pm
Coopervid wrote: Sun Feb 16, 2025 6:22 pm
PM sent.
Hi Coopervid, got your PM: Yes, please send next PM
spectrumpursuit
#104 Post by spectrumpursuit » Sat Feb 22, 2025 1:52 am
Hi Coopervid, I have the Verbatim 43890 that doesn't work reading 4k disks - can you please help?
Revision: 1.14
Serial number:xxxxxxxxxx
enolagay
#105 Post by enolagay » Sat Feb 22, 2025 4:36 am
Here are my details. I would appreciate it if you could help me to get it reading UHD discs.
Revision: 1.14
Serial number:
Highest AACS version: 81
