Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
dizzycreator
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by dizzycreator »
Yes, please send next PM.
dizzycreator
Currently in the 43890's factory state I put in a 4K disc and it spins it a few times then spits it out. It reads HD discs, but spits out UHD/4K discs.
Info from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
zeemysteryman
Post by zeemysteryman »
I have the opportunity to go get one of these. As of now, are they still flashable for UHD?
dizzycreator
Just got the flash today and it worked first try. Thank you coopervid!!
I did the flash on a PC, but I'm using makemkv on a mac. Getting macos Sequoia to playback .mkv files properly with the HDR tone mapping to my display was a separate ordeal. I finally got it to work with Movist Pro.
megaturkey
Post by megaturkey »
Got my blu-ray collection backed up with this drive. All was well, but apparently, it won't work for 4K. Any help would be greatly appreciated if possible.
OS device name: G:
Revision: 1.11
Serial number:
Firmware date: 2018-11-28
Highest AACS version: 50
Firmware version: 1.11
spacegodzilla11
Post by spacegodzilla11 »
enolagay
Post by enolagay »
Would it be possible for you to send me a copy of this flasher? I picked up one of these drives and would love to get it reading UHD as well. Thanks!
Fox_Mulder
Post by Fox_Mulder »
Coopervid wrote:
Fri Jan 10, 2025 2:18 pm
Fox_Mulder wrote:
Fri Jan 10, 2025 2:10 am
Coopervid wrote:
Thu Jan 09, 2025 9:25 pm
Post your Makemkv info.
How much should the firmware cost? I'm trying to decide which is more worthwhile.
I don't charge for it but you are free to send some bucks as appreciation.
I was now able to buy a 43890.
Laufwerksinformation
OS-Gerätename: J:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: **************
Firmware-Datum: 2020-06-15
Highest AACS version: 77
@Coopervid
I hope that the hardware is ok for firmware UD04?
Robo111
Post by Robo111 »
Hi Coopervid, I have the Verbatim 43890 - that isn't reading 4k - can you help me please?
OS device name: H:
Revision: 1.14
Serial number:
Fox_Mulder wrote:
Thu Feb 20, 2025 6:23 pm
OS-Gerätename: J:
Produzent: PIONEER
Revision: 1.14
@Coopervid
PM is coming.
Robo111 wrote:
Fri Feb 21, 2025 7:48 am
OS device name: H:
Revision: 1.14
Serial number:
PM sent.
slickpic
Post by slickpic »
Coopervid wrote:
Sun Feb 16, 2025 6:22 pm
PM sent.
Hi Coopervid, got your PM: Yes, please send next PM
spectrumpursuit
Post by spectrumpursuit »
Hi Coopervid, I have the Verbatim 43890 that doesn't work reading 4k disks - can you please help?
Revision: 1.14
Serial number:xxxxxxxxxx
enolagay
Post by enolagay »
Here are my details. I would appreciate it if you could help me to get it reading UHD discs.
Revision: 1.14
Serial number:
Highest AACS version: 81
