LibreDrive for Pioneer drives
#1306 Post by Billycar11 » Thu Feb 13, 2025 4:05 pm
belze wrote: Thu Feb 13, 2025 4:02 pm Can this drive be made to read and rip UHD discs?
I tried one and it would not be recognized, thanks for any help!
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.50
Serienummer: REDL014741WL
Firmware-Datum: 2017-12-21
Drive platform: RS8601
Firmware version: 8.50/ID52
Email me that see below for the flasher
boilerdad
#1307 Post by boilerdad » Sat Feb 15, 2025 1:00 am
@Coopervid
This fw is old enough it is working for regular blu-ray but it won't let me open 4k UHD discs. I read through several on this thread that looks like you PM'd a solution. Would it apply to this drive?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: ...
Firmware date: 2014-12-26
Highest AACS version: 75
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Thank you
#1308 Post by Coopervid » Sat Feb 15, 2025 10:59 am
boilerdad wrote: Sat Feb 15, 2025 1:00 am @Coopervid
OS device name: F:
Revision: 3.01
Serial number: ...
Thank you
Yes.
boilerdad
#1309 Post by boilerdad » Sat Feb 15, 2025 5:12 pm
THank you, also saw your other post saying to mail those other two guys for a flasher so sent one an email. Sorry for the bother, just getting in to all of this. Appreciate the info.
#1310 Post by Coopervid » Sat Feb 15, 2025 9:19 pm
boilerdad wrote: Sat Feb 15, 2025 5:12 pm THank you, also saw your other post saying to mail those other two guys for a flasher so sent one an email. Sorry for the bother, just getting in to all of this. Appreciate the info.
PM sent.
tinkeringtanuki
#1311 Post by tinkeringtanuki » Sun Feb 16, 2025 7:43 am
Lucky enough to happen to have a pre 2022 drive I had originally gotten to burn some M-Discs.
Paranoid of doing something to screw it up but I assume it needs to be patched or something to allow it to rip or should it with with UHD as is?
OS device name: /dev/rdisk4
Product: BD-RW BDR-XS07U
Revision: 1.01
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 62
Drive platform: RS8E21
Firmware version: 1.01/ID05
#1312 Post by MartyMcNuts » Sun Feb 16, 2025 12:33 pm
tinkeringtanuki wrote: Sun Feb 16, 2025 7:43 am Lucky enough to happen to have a pre 2022 drive I had originally gotten to burn some M-Discs.
Revision: 1.01
That should work as is. Don't ever update it!
pitt1717
#1313 Post by pitt1717 » Tue Feb 18, 2025 2:14 am
So i got a question. maybe its the long weekend....... anyway, i posted in the bdr-xd05s thread because i thought or think the drive got cracked and it could now read UHD.
Then i started reading this thread and it states even though the drive and firmware were added to the sdf file, and the libredrive is a yes in the drive details of MKV, unless the drive has a U in the model it can't read 4k BD's.
can someone clarify for me please. with this drive read 4k UHD disks or do i need to buy a new drive. Been buying multi-packs the last year, and if i can get this drive to work it would be awesome. Would love to see if my local streaming can support it
thanks all
#1314 Post by MartyMcNuts » Tue Feb 18, 2025 6:43 am
pitt1717 wrote: Tue Feb 18, 2025 2:14 am So i got a question. maybe its the long weekend....... anyway, i posted in the bdr-xd05s thread because i thought or think the drive got cracked and it could now read UHD.
thanks all
Libredrive does not equal UHD readability!! If the Pioneer drive is not a UHD model, then no it cannot read UHD discs unless you can cross-flash it to a UHD model. For that, you should contact Billycar11.
8u5jl
#1315 Post by 8u5jl » Tue Feb 18, 2025 10:33 am
This should work as is, right? no need to reflash or anything. Just bought this one (sold as a Verbatim 43888), I got lucky I think.
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DGDL156947WL
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8A10
Firmware version: 1.14
#1316 Post by MartyMcNuts » Tue Feb 18, 2025 10:40 am
8u5jl wrote: Tue Feb 18, 2025 10:33 am This should work as is, right? no need to reflash or anything. Just bought this one (sold as a Verbatim 43888), I got lucky I think.
Revision: 1.14
Yes, good to go!
pitt1717
#1317 Post by pitt1717 » Tue Feb 18, 2025 10:32 pm
MartyMcNuts wrote: Tue Feb 18, 2025 6:43 am
thanks all
got it.
so one other question. if i look through the sdf file to find a drive i am interested in. And i buy it and it has the correct firmware, i shouldn't have to do anything then correct? no flashing etc... If i read and understand correctly,when mkv sees the drive and its in the sdf, it does all the memory magic (per the whats libredrive post) between the software and hardware and the drive becomes unlocked/region free and can rip regular dvd/bd, and 4k UHD?
#1318 Post by MartyMcNuts » Tue Feb 18, 2025 11:08 pm
pitt1717 wrote: Tue Feb 18, 2025 10:32 pm
thanks all
got it.
Pretty much all new LG/ASUS (and offshoots like Archgon, Buffalo etc) drives will require flashing. The only drive that does not require flashing and works OOTB is the Verbatim 43888 (containing a Pioneer BDR-UD04 inside). There are now two versions of the Verbatim 43888, one contains a Pioneer drive, the other an LG BU40N which needs to be flashed. If you want a Pioneer drive, check with the sellers on this forum as store bought are not compatible.
pitt1717
#1319 Post by pitt1717 » Wed Feb 19, 2025 11:58 pm
thanks for the help, much appreciated
jspace
#1320 Post by jspace » Sat Feb 22, 2025 12:47 am
Haven't updated in a while. The rest of the drives I ordered showed up. The BDR-212V also had pre December firmware on it, so there's that.
