Resultant mkv is VFR?
doobre
Post by doobre »
Hi there, just wondering if anyone has come across this weird output issue.
When ripping a BD of Sheryl Crow - Soundstage the output from MakeMkv shows in mediainfo as variable frame rate and handbrake refuses to encode it.
VFR is not a valid format in BD terms so I doubt that a commercially produced disk would be using such a 'trick'.
When the makemkv output is played back in VLC and PowerDVD12, the video is playing at double speed compared to the audio.
As I said weird, never come across something like this before, and I have copied many BD's.
cheers CD
here is the mediainfo details for the output--
General
Complete name : D:\EXPORTS\MakeMKV_Export\SHERYL_CROW_LIVE\Sheryl Crow - Live on Soundstage.mkv
Format : Matroska
Format version : Version 2
File size : 25.1 GiB
Duration : 1 h 31 min
Overall bit rate mode : Variable
Overall bit rate : 39.1 Mb/s
Frame rate : 59.940 FPS
Encoded date : 2025-02-14 02:11:53 UTC
Writing application : MakeMKV v1.17.7 win(x64-release)
Writing library : libmakemkv v1.17.7 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=2, N=26
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 30.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 (60000/1001) FPS
Original frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.241
Stream size : 19.2 GiB (77%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate : 4 697 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.02 GiB (12%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 993 MiB (4%)
Language : English
Default : No
Forced : No
Audio #3
ID in the original source medium : 4353 (0x1101)
Format : PCM
Format settings : Little / Signed
Codec ID : A_PCM/INT/LIT
Bit rate : 2 304 kb/s
Channel(s) : 2 channels
Frame rate : 30.000 FPS (1600 SPF)
Bit depth : 24 bits
Stream size : 1.48 GiB (6%)
Title : Stereo
Language : English
Default : No
Forced : No
Audio #4
ID in the original source medium : 4354 (0x1102)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate : 640 kb/s
Channel layout : L R C LFE Ls Rs
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 421 MiB (2%)
Language : English
Service kind : Complete Main
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 00
00:00:09.809 : en:Chapter 01
00:00:49.516 : en:Chapter 02
00:05:20.453 : en:Chapter 03
00:11:16.609 : en:Chapter 04
00:15:17.583 : en:Chapter 05
00:22:05.624 : en:Chapter 06
00:25:43.975 : en:Chapter 07
00:30:48.279 : en:Chapter 08
00:36:15.640 : en:Chapter 09
00:41:35.926 : en:Chapter 10
00:48:28.772 : en:Chapter 11
00:52:13.597 : en:Chapter 12
00:57:41.191 : en:Chapter 13
01:04:17.987 : en:Chapter 14
01:08:59.635 : en:Chapter 15
01:14:27.696 : en:Chapter 16
01:19:33.668 : en:Chapter 17
01:26:17.939 : en:Chapter 18
Re: Resultant mkv is VFR?
What happens if you make a decrypted backup of the disc (icon of yellow folder with green arrow on the first screen in MakeMKV) and then use MKVToolNix on the backup to create a .mkv file?
doobre
Post by doobre »
Hi there, thanks for the reply.
I got around the problem by ripping with handbrake.
But out of interest I will follow your suggestion and get back here.
Cheers CD
doobre
Post by doobre »
Hey dcoke22
That sorted it out, but think it might be of interest to the dev's to understand what went 'wrong'..
here's the mediainfo fot the backup .m2ts stream file.
cheers for the suggestion.
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Bit depth : 8 bits
