3d with truehd
Everything related to Blu-ray 3D and 3D MKV files
blusmurfz
3d with truehd
Post by blusmurfz »
I have a makemkv rip of a 3d blu-ray and I'm trying to use bd3dmk3d to convert it. No matter what I can't get audio. It says that if doing it with a truehd audio track that it will need to run twice. Ok? Doesn't seem to work. No audio still. I had two files that this has happened with.
Any help is greatly appreciated.
Re: 3d with truehd
blusmurfz wrote: Sat Feb 15, 2025 2:32 am I have a makemkv rip of a 3d blu-ray and I'm trying to use bd3dmk3d to convert it. No matter what I can't get audio. It says that if doing it with a truehd audio track that it will need to run twice. Ok? Doesn't seem to work. No audio still. I had two files that this has happened with.
Once you have the 3d mkv file just use mkv toolbox to put the truehd audio track back in.
blusmurfz
Re: 3d with truehd
Post by blusmurfz »
MartyMcNuts wrote: Sat Feb 15, 2025 5:32 am Once you have the 3d mkv file just use mkv toolbox to put the truehd audio track back in.
You're the best! Worked like a charm. I forgot about this software.
Now to find foreign only subtitles and get them forced in (for a diff 3d movie).
