Deadpool 1 Blu Ray Volume Key Unknown
kdubbs29
#1 Post by kdubbs29 » Sat Feb 15, 2025 6:16 pm
Can someone please help me, Deadpool 1 on Blu Ray won't open. This disc uses newer version of AACS protection. The volume key is unknown for this disc - video can't be decrypted.
Here is a link to the dump file. https://we.tl/t-hWhGxDi4tn
Thank you!!!
Re: Deadpool 1 Blu Ray Volume Key Unknown
#2 Post by dcoke22 » Tue Feb 18, 2025 3:04 pm
If you don't have a LibreDrive endabled drive, and the AACS version you've encountered on that disc is higher than AACS v81 (the highest MakeMKV supports at the moment), you'll have to wait until a new version of MakeMKV comes out with support for whatever version of AACS you're running into.
chihwahli
#3 Post by chihwahli » Fri Mar 21, 2025 11:51 am
I own that bluray (2K and 4K version) movie also. The only way you can copy it is to flash your drive with the tool, and make it libre:
https://uhdenableddrives.com/
I own the Hitachi LG BU40N and the tool seller said I can use both his tool with firmware 1.00 or 1.03MK.
Bought the 1.03MK version and re-flashed my drive. And now it is working. Just made a personal copy in case my bluray and my families 4K bluray are broken. So, that I do not need to re-buy them, as their prices usually stay expensive in my opinion. One time bying is already expensive enough.
The tool is known by the MakeMKV admins. I also scanned it with my Malwarebytes. So far all ok.
Just wanted to say. It works like a pancake you made with all flavours you ever wanted.
