Auto dvd ripping
Ezatoka
Re: Auto dvd ripping
Post by Ezatoka »
bob5731 wrote: Fri Feb 14, 2025 9:59 pm I would like to the the files in mp4.
The program is called MakeMKV, not MakeMP4. That's not configurable.
Plex can handle MKV files. The auto-rip-and-eject is your issue.
DVDs are less likely to have names embedded in them than BDs, so you are going to have to manually handle them in any case.
flojo
Post by flojo »
Woodstock wrote: Sat Feb 15, 2025 3:54 am ... manually handle them ...
Take a pic with a cheap webcam, name both the pic and the directory with a common timestamp then name them later.
now=$(date +%s,%N)
mkdir "$now" # make the directory to rip to
makemkvcon backup --decrypt --cache=16 --noscan -r --progress=-same disc:0 "${now}/"
eject /dev/sr0
sleep 8 # wait for tray to open
ffmpeg -f video4linux2 -s 1920x1080 -i /dev/video0 -ss 0:0:2 -frames 1 "${now}.jpg"
In a thread named "Auto dvd ripping"... you must start to build something auto'ish :-). This really won't happen without at least balls-basic scripting like I posted above, so if the OP wants to do this, now is the time to take the toddler intro course to scripting using at least Bash or something higher like Pearl, Javascript, Python, etc.
flojo
Post by flojo »
You're a robot.
LLM's need a disclaimer, otherwise it's automated trolling.
