I have a makemkv rip of a 3d blu-ray and I'm trying to use bd3dmk3d to convert it. No matter what I can't get audio. It says that if doing it with a truehd audio track that it will need to run twice. Ok? Doesn't seem to work. No audio still. I had two files that this has happened with.
Any help is greatly appreciated.
3d with truehd
Re: 3d with truehd
Once you have the 3d mkv file just use mkv toolbox to put the truehd audio track back in.blusmurfz wrote: Sat Feb 15, 2025 2:32 am I have a makemkv rip of a 3d blu-ray and I'm trying to use bd3dmk3d to convert it. No matter what I can't get audio. It says that if doing it with a truehd audio track that it will need to run twice. Ok? Doesn't seem to work. No audio still. I had two files that this has happened with.
Re: 3d with truehd
You're the best! Worked like a charm. I forgot about this software.MartyMcNuts wrote: Sat Feb 15, 2025 5:32 am Once you have the 3d mkv file just use mkv toolbox to put the truehd audio track back in.
Now to find foreign only subtitles and get them forced in (for a diff 3d movie).
