The program is called MakeMKV, not MakeMP4. That's not configurable.
Auto dvd ripping
Ezatoka
Re: Auto dvd ripping
Plex can handle MKV files. The auto-rip-and-eject is your issue.
DVDs are less likely to have names embedded in them than BDs, so you are going to have to manually handle them in any case.
flojo
Take a pic with a cheap webcam, name both the pic and the directory with a common timestamp then name them later.
now=$(date +%s,%N)
mkdir "$now" # make the directory to rip to
makemkvcon backup --decrypt --cache=16 --noscan -r --progress=-same disc:0 "${now}/"
eject /dev/sr0
sleep 8 # wait for tray to open
ffmpeg -f video4linux2 -s 1920x1080 -i /dev/video0 -ss 0:0:2 -frames 1 "${now}.jpg"
flojo
You're a robot.
LLM's need a disclaimer, otherwise it's automated trolling.
