MakeMKV Speed Issue
spl147
MakeMKV Speed Issue
Post by spl147 » Fri Feb 14, 2025 3:13 pm
i have seen a serious speed decrease in processing files since 1.17.8, anyone else?
here is 1.17.9:
here is 1.17.7:
flojo
Re: MakeMKV Speed Issue
Post by flojo » Fri Feb 14, 2025 4:22 pm
107x speed?? I assume with file input?
Anyways, 17.8/9 have some bugs, stay with 17.7/6.
Post by dcoke22 » Fri Feb 14, 2025 5:49 pm
flojo wrote: Fri Feb 14, 2025 4:22 pm 107x speed?? I assume with file input?
My default workflow is make a decrypted backup of the disc, then open the backup and create .mkv files from there. I often see speeds in that range when creating .mkv files from the backup.
I've been lazy and am still on 1.17.6 so I can't confirm the OP's observations. However, I've seen other comments to the same effect on the forums.
spl147
Post by spl147 » Fri Feb 14, 2025 5:50 pm
yes, file input.
flojo
Post by flojo » Fri Feb 14, 2025 7:24 pm
dcoke22 wrote: Fri Feb 14, 2025 5:49 pm I've seen other comments to the same effect on the forums.
Yeh I think I've seen 3 different bugs for 17.8/9 reported on here. Also dtech's thread viewtopic.php?f=3&t=33061 could be an oversight/missed opportunity that could be remedied. Regardless, it might be code maintenance time.
