Non-crashing show stopper.
holyrunts
Post by holyrunts »
I am trying to create a MKV from a non-encrypted disc. It fails every time, but it does not crash the app. This is the only log file that I can find. If I am missing a vital piece of information, I apologize.
Debug log started at Wed Oct 14 05:05:01 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/*******/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at %$K'7k/|wNr!5t\jn#?F9B<s@CM:121264878
003006:000000:0000 Opening files on harddrive at /Volumes/*******/
003310:000000:0000 AACS directory not present, assuming unencrypted disc
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00003
003313:000000:0000 File 00016.mpls was added as title #0
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00229.m2ts
003308:000000:0000 Stream #20 of type 'DTS-HD secondary audio' in file 00229.m2ts was skipped
003308:000000:0000 Stream #26 of type 'DTS-HD secondary audio' in file 00229.m2ts was skipped
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00001.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00002.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00221.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00030.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00031.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00005.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00006.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00007.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00008.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00032.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00010.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00011.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00012.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00013.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00014.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00015.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00016.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00017.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00018.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00019.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00020.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00021.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00022.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00023.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00024.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00025.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00026.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00027.m2ts
003313:000000:0000 File 00017.mpls was added as title #1
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00206.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00207.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00208.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00209.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00210.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00211.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00212.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00213.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00214.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00215.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00216.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00217.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00218.m2ts
003313:000000:0000 File 00018.mpls was added as title #2
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00219.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00220.m2ts
003313:000000:0000 File 00019.mpls was added as title #3
003314:000000:0000 Title 00020.mpls is equal to title 00017.mpls and was skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00031
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00079
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00080
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00099
003314:000000:0000 Title 00100.mpls is equal to title 00017.mpls and was skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00121
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00126
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00127
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00128
003313:000000:0000 File 00137.mpls was added as title #4
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00139
003313:000000:0000 File 00156.mpls was added as title #5
003313:000000:0000 File 00033.m2ts was added as title #6
003313:000000:0000 File 00034.m2ts was added as title #7
003313:000000:0000 File 00035.m2ts was added as title #8
003020:000000:0000 Title #00036.m2ts has length of 0 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003313:000000:0000 File 00037.m2ts was added as title #9
003313:000000:0000 File 00103.m2ts was added as title #10
003020:000000:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003313:000000:0000 File 00105.m2ts was added as title #11
003313:000000:0000 File 00134.m2ts was added as title #12
003313:000000:0000 File 00135.m2ts was added as title #13
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00136.m2ts
003313:000000:0000 File 00136.m2ts was added as title #14
003313:000000:0000 File 00139.m2ts was added as title #15
003313:000000:0000 File 00140.m2ts was added as title #16
003313:000000:0000 File 00141.m2ts was added as title #17
003313:000000:0000 File 00142.m2ts was added as title #18
003313:000000:0000 File 00143.m2ts was added as title #19
003313:000000:0000 File 00144.m2ts was added as title #20
003313:000000:0000 File 00145.m2ts was added as title #21
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00146.m2ts
003313:000000:0000 File 00146.m2ts was added as title #22
003020:000000:0000 Title #00157.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003313:000000:0000 File 00159.m2ts was added as title #23
003313:000000:0000 File 00160.m2ts was added as title #24
003313:000000:0000 File 00161.m2ts was added as title #25
003313:000000:0000 File 00162.m2ts was added as title #26
003020:000000:0000 Title #00164.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00181.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00182.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00183.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003313:000000:0000 File 00188.m2ts was added as title #27
003313:000000:0000 File 00190.m2ts was added as title #28
003313:000000:0000 File 00191.m2ts was added as title #29
003313:000000:0000 File 00192.m2ts was added as title #30
003313:000000:0000 File 00193.m2ts was added as title #31
003313:000000:0000 File 00194.m2ts was added as title #32
003313:000000:0000 File 00195.m2ts was added as title #33
003313:000000:0000 File 00196.m2ts was added as title #34
003313:000000:0000 File 00197.m2ts was added as title #35
003313:000000:0000 File 00198.m2ts was added as title #36
003313:000000:0000 File 00199.m2ts was added as title #37
003313:000000:0000 File 00200.m2ts was added as title #38
003313:000000:0000 File 00201.m2ts was added as title #39
003313:000000:0000 File 00202.m2ts was added as title #40
003313:000000:0000 File 00203.m2ts was added as title #41
003313:000000:0000 File 00204.m2ts was added as title #42
003308:000000:0000 Stream #3 of type 'DTS-HD secondary audio' in file 00224.m2ts was skipped
003313:000000:0000 File 00224.m2ts was added as title #43
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00225.m2ts
003313:000000:0000 File 00225.m2ts was added as title #44
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00226.m2ts
003313:000000:0000 File 00226.m2ts was added as title #45
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00227.m2ts
003313:000000:0000 File 00227.m2ts was added as title #46
003313:000000:0000 File 00228.m2ts was added as title #47
003020:000000:0000 Title #00230.m2ts has length of 0 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003313:000000:0000 File 00236.m2ts was added as title #48
003313:000000:0000 File 00237.m2ts was added as title #49
003313:000000:0000 File 00239.m2ts was added as title #50
003020:000000:0000 Title #00240.m2ts has length of 0 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00241.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00242.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00243.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00244.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00245.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00246.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00247.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00248.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00250.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00251.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00252.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00253.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00254.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00255.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00256.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00257.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00258.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00259.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00260.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00261.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00262.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00263.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00264.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00265.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00266.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00267.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00268.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00269.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00270.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00271.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00272.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00273.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00274.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00275.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00276.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00277.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00278.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00279.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00280.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00281.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00282.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00283.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00284.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00285.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00286.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00287.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00288.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00289.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00290.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00291.m2ts has length of 0 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003020:000000:0000 Title #00294.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /Users/*******/
Re: Non-crashing show stopper.
Post by mike admin »
I do not see any errors in a log file. Does it fail after you press "make mkv" button or during disc open?
holyrunts
Post by holyrunts »
mike admin wrote:I do not see any errors in a log file. Does it fail after you press "make mkv" button or during disc open?
It fails after I press the "make mkv" button. It starts encoding, and then it throws an error message in the middle of encoding. I'll try again, and then screen cap what happens. Maybe that will help to diagnose the problem.
