Should be four episodes but MakeMKV is finding a single 4GB title and saying it has two angles which is not right.
Seems like I'm not able to rip from anything that is anime, I guess that is where all the copy protection is being put.
Speed Grapher - can't find titles
crazy4nookie
- Speed Grapher.zip
- (150.1 KiB) Downloaded 679 times
crazy4nookie
Re: Speed Grapher - can't find titles
Debug log started at Fri Nov 18 02:53:03 2011 , written by MakeMKV v1.6.16 darwin(x86-release)
Using 458880KB for read cache.
001005:0000 MakeMKV v1.6.16 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/doug/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5670S 2AHI" opened in DASPI v1.3 mode.
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003028:0000 Title #0 was added (5 cell(s), 0:02:36)
Title skip vts=1 pgcn=2 hash=60ECA301681CD8BC
003028:0000 Title #2 was added (1 cell(s), 0:12:29)
003025:0000 Title #3 has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/1 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/2 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/3 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/4 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/5 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/6 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 20 cells and 4473 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #5 was added (40 cell(s), 1:33:15)
003024:1000 Complex multiplex encountered - 20 cells and 4466 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003040:0000 Angle #2 was added for title #5
003025:0000 Title #6 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6/1 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at fIpm8c1LsOH3+/3iMWMeRLHB:0
Twowit2woo
It could be 1 title. Is it all four episodes together?
What's the film length when you play it in VLC?
Not having this particular DVD, I can say that a lot of Funimation titles have only a single file that contains all episodes. It runs about 50/50 on the Funimation titles I own.
crazy4nookie
I think you guys are right, thanks. I haven't flipped through it to verify they are all there but the length after ripping is an hour and thirty (I didn't do the rip previously). So the only other question is why does it find a second camera angle. I have two 4GB angles where one has 36 chapters and the other has 16 chapters. It looks like they are both the same length.
I'm going to attach a screenshot here.
- two angles.png (34.44 KiB) Viewed 17666 times
crazy4nookie
I guess that really is how the DVD is. I just pulled it up in DVD Player and it says there is a second angle available. There isn't any viewing options in the DVD menu itself though, so who knows what that is about.
I encountered the same thing with my Fate/Stay Night collection. Is there a workaround for this or is the DVD mastered badly?
