Email me that see below for the flasherbelze wrote: Thu Feb 13, 2025 4:02 pm Can this drive be made to read and rip UHD discs?
I tried one and it would not be recognized, thanks for any help!Code: Select all
Laufwerksinformation OS-Gerätename: D: Produzent: PIONEER Produkt: BD-RW BDR-209M Revision: 8.50 Serienummer: REDL014741WL Firmware-Datum: 2017-12-21 Markierungen der Bus-Verschlüsselung: 1B LibreDrive Information Status: Enabled Drive platform: RS8601 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 8.50/ID52 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
LibreDrive for Pioneer drives
boilerdad
@Coopervid
This fw is old enough it is working for regular blu-ray but it won't let me open 4k UHD discs. I read through several on this thread that looks like you PM'd a solution. Would it apply to this drive?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: ...
Firmware date: 2014-12-26
Highest AACS version: 75
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Thank you
OS device name: F:
Revision: 3.01
Serial number: ...
Thank you
Yes.boilerdad wrote: Sat Feb 15, 2025 1:00 am @Coopervid
OS device name: F:
Revision: 3.01
Serial number: ...
Thank you
boilerdad
THank you, also saw your other post saying to mail those other two guys for a flasher so sent one an email. Sorry for the bother, just getting in to all of this. Appreciate the info.
PM sent.boilerdad wrote: Sat Feb 15, 2025 5:12 pm THank you, also saw your other post saying to mail those other two guys for a flasher so sent one an email. Sorry for the bother, just getting in to all of this. Appreciate the info.
tinkeringtanuki
Lucky enough to happen to have a pre 2022 drive I had originally gotten to burn some M-Discs.
Paranoid of doing something to screw it up but I assume it needs to be patched or something to allow it to rip or should it with with UHD as is?
OS device name: /dev/rdisk4
Product: BD-RW BDR-XS07U
Revision: 1.01
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 62
Drive platform: RS8E21
Firmware version: 1.01/ID05
Revision: 1.01
That should work as is. Don't ever update it!tinkeringtanuki wrote: Sun Feb 16, 2025 7:43 am Lucky enough to happen to have a pre 2022 drive I had originally gotten to burn some M-Discs.
Revision: 1.01
pitt1717
So i got a question. maybe its the long weekend....... anyway, i posted in the bdr-xd05s thread because i thought or think the drive got cracked and it could now read UHD.
Then i started reading this thread and it states even though the drive and firmware were added to the sdf file, and the libredrive is a yes in the drive details of MKV, unless the drive has a U in the model it can't read 4k BD's.
can someone clarify for me please. with this drive read 4k UHD disks or do i need to buy a new drive. Been buying multi-packs the last year, and if i can get this drive to work it would be awesome. Would love to see if my local streaming can support it
thanks all
thanks all
Libredrive does not equal UHD readability!! If the Pioneer drive is not a UHD model, then no it cannot read UHD discs unless you can cross-flash it to a UHD model. For that, you should contact Billycar11.pitt1717 wrote: Tue Feb 18, 2025 2:14 am So i got a question. maybe its the long weekend....... anyway, i posted in the bdr-xd05s thread because i thought or think the drive got cracked and it could now read UHD.
thanks all
8u5jl
This should work as is, right? no need to reflash or anything. Just bought this one (sold as a Verbatim 43888), I got lucky I think.
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DGDL156947WL
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8A10
Firmware version: 1.14
Unrestricted read speed: Yes-
Yes, good to go!8u5jl wrote: Tue Feb 18, 2025 10:33 am This should work as is, right? no need to reflash or anything. Just bought this one (sold as a Verbatim 43888), I got lucky I think.
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-UD04 Revision: 1.14 Serial number: DGDL156947WL Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8A10 Firmware name: PIONEER BDR-US04 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
pitt1717
got it.MartyMcNuts wrote: Tue Feb 18, 2025 6:43 amLibredrive does not equal UHD readability!! If the Pioneer drive is not a UHD model, then no it cannot read UHD discs unless you can cross-flash it to a UHD model. For that, you should contact Billycar11.pitt1717 wrote: Tue Feb 18, 2025 2:14 am So i got a question. maybe its the long weekend....... anyway, i posted in the bdr-xd05s thread because i thought or think the drive got cracked and it could now read UHD.
thanks all
so one other question. if i look through the sdf file to find a drive i am interested in. And i buy it and it has the correct firmware, i shouldn't have to do anything then correct? no flashing etc... If i read and understand correctly,when mkv sees the drive and its in the sdf, it does all the memory magic (per the whats libredrive post) between the software and hardware and the drive becomes unlocked/region free and can rip regular dvd/bd, and 4k UHD?
Pretty much all new LG/ASUS (and offshoots like Archgon, Buffalo etc) drives will require flashing. The only drive that does not require flashing and works OOTB is the Verbatim 43888 (containing a Pioneer BDR-UD04 inside). There are now two versions of the Verbatim 43888, one contains a Pioneer drive, the other an LG BU40N which needs to be flashed. If you want a Pioneer drive, check with the sellers on this forum as store bought are not compatible.pitt1717 wrote: Tue Feb 18, 2025 10:32 pmgot it.MartyMcNuts wrote: Tue Feb 18, 2025 6:43 amLibredrive does not equal UHD readability!! If the Pioneer drive is not a UHD model, then no it cannot read UHD discs unless you can cross-flash it to a UHD model. For that, you should contact Billycar11.pitt1717 wrote: Tue Feb 18, 2025 2:14 am So i got a question. maybe its the long weekend....... anyway, i posted in the bdr-xd05s thread because i thought or think the drive got cracked and it could now read UHD.
thanks all
pitt1717
thanks for the help, much appreciated
jspace
Haven't updated in a while. The rest of the drives I ordered showed up. The BDR-212V also had pre December firmware on it, so there's that.
