Se7en 4k Error
strangetoes85
Se7en 4k Error
Post by strangetoes85 » Wed Feb 12, 2025 11:53 pm
Getting this error from the Se7en 4K. Cleaned the disc and tried again but to no avail.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00079.m2ts' at offset '61837406208'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '61837406208'
Failed to save title 9 to file T:/Video/Se7en/Se7en_t09.mkv
0 titles saved, 1 failed
Re: Se7en 4k Error
Post by dcoke22 » Thu Feb 13, 2025 4:11 am
Is your optical drive powered by USB? If so, it looks like the drive isn't getting enough power.
strangetoes85
Re: Se7en 4k Error
Post by strangetoes85 » Thu Feb 13, 2025 6:01 pm
dcoke22 wrote: Thu Feb 13, 2025 4:11 am Is your optical drive powered by USB? If so, it looks like the drive isn't getting enough power.
No, the drive has a separate power source. To make sure, I just finished a 4K copy of Hot Fuzz with no issues. So I'm guessing it's something with the disc, or maybe something specific to Warner Bros discs
wbradm
Re: Se7en 4k Error
Post by wbradm » Wed May 07, 2025 3:47 pm
Have you been able to find a solution? I purchased the Se7en 4k release in the cardboard slip cover, and I am having the same issue. I was debating buying another UHD friendly drive to see if it might just not be compatible with my current drive.
