KEY NOT PRESENT error
cryox
Post by cryox »
I'm receiving a lot of 'KEY NOT PRESENT' and some 'KEY NOT ESTABLISHED' errors using the linux version:
MakeMKV v1.17.8 linux(x64-release) started
Backing up disc into folder ...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Saved AACS dump file as ...
Backup failed
What I tried so far (always the same drive with the same BluRay):
Machine A (Arch) -> MakeMKV from AUR -> fails
Machine A (Arch) -> MakeMKV from Flatpak -> fails
Machine A (Arch) -> Ubuntu VM -> MakeMKV built as described here -> fails
Machine A (Arch) -> Windows VM -> MakeMVK from the website -> works
Machine B (Windows) -> MakeMVK from the website -> works
So I'm pretty confident there is something wrong with the Linux version. Also, since running it on a vanilla Ubuntu 24.10 VM using the manual as described doesn't work.
Has anyone faced a similar issue and was able to solve it?
Re: KEY NOT PRESENT error
Is your drive LibreDrive compatible? Have you flashed it to enable LibreDrive?
hobbified
Post by hobbified »
Same thing here. Yes it's a compatible drive, a BRUHD-PU3-BK that I flashed. Rips work okay on MakeMKV 1.17.9 for Windows, but if I take the same drive and same disc and plug them into my Linux machine the copying process will start, then after a few seconds the drive spins down and there are a bunch of SCSI NOT READY errors, then when it spins up again it shows the KEY NOT PRESENT error several times. It continues copying data but the results are garbage. Kernel logs show
sr 7:0:0:0: Power-on or device reset occurred
at the same time. So it seems like it's essentially crashing the drive.
Another possibility is that it powered down, due to an over-speed condition. If the USB port isn't a "fully compatible" USB3 port, a drive can run out of power with only one plug inserted. This would tend to happen on a long read.
If it's happening right after the read starts, it would be strange.
cryox
Post by cryox »
Thanks for your suggestions! As indicated in the original post, the same drive, with the same firmware, same disc, same PC and same USB-Port works just fine when using Windows.
I can't really find any other reason than there is something missing or broken with the Linux version.
cryox
Post by cryox »
Problem still present in 1.17.9
I could further narrow it down: It works with normal Blu-rays (tested with AACS v28), but not with UHD Blu-rays (tested with AACS2.0/C v77).
The issue is probably related to how MakeMKV handles UHD decryption on Linux.
Can anyone give further hints to where to look for insights?
HeyQuitThat
Post by HeyQuitThat »
Just to jump on this bandwagon, I'm seeing the same thing. Linux Mint 22.1 on x86_64. I'm running an LG BU40N with patched firmware 1.03MK. It rips DVDs OK in Linux but chokes on UHD. Same exact setup works in Windows. I'm running registered Make MKV 1.17.9.
I've seen it suggested on this forum that a BU40N needs to be flashed to firmware 1.00 to work the best on Linux.
https://forum.makemkv.com/forum/viewtopic.php?p=154090#p154090
