Playing UHDs in VLC with WH16NS60
TylerJaacks
Post by TylerJaacks » Thu Feb 06, 2025 12:37 am
Is it possible to play (not rip) UHD movies in VLC with the WH16NS60?
I have MakeMKV open and it detects my drive and will rip properly.
I have a System C:\WINDOWS/System32, System (32bit) C:\WINDOWS/SysWOW64 and VLC C:\Program Files\VideoLAN\VLC all checked.
I have libaacs.dll in the VLC folder and drl and hrl in my %RoamingAppData%/aacs folder
When I open VLC and go to Media -> Open Disc and select Blu-ray and select play it just loads for a while and then says
Blu-ray error:
Failed to start bluray playback. Please try without menu support.
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///F:/'. Check the log for details.
Disabling menus did seem to work I believe I was just hoping I could get it working with menus.
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:
Highest AACS version: 76
Firmware version: 1.02
Disc Information
Label: GHOST_IN_THE_SHELL_UHD
Timestamp: 2020-08-02 11:23:09
Protection: AACS2.0/C v76
Data capacity: 63.34 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Re: Playing UHDs in VLC with WH16NS60
Post by dcoke22 » Tue Feb 11, 2025 8:23 am
If my memory is correct, I think you need Java for most blu-ray menus to work. It has been a long time since I tried to play a blu-ray with VLC, so I don't have much experience with it. I just rip my discs and play the files; it seems easier. :)
Yethidran
Post by Yethidran » Tue Feb 11, 2025 9:29 am
1) in makemkv preferences, make sure the "Integration Tab" has been checked marked for vlc.
2) when you open vlc, go to the "Media Tab" and click on it, then go to "Open Disc", once that is done, choose the "Blu-ray button" not the "DVD" button.
3) for me, i also do an extra step by clicking on the "No Disc Menus button"
4) the uhd movie then can be played without menus or hiccups.
5) if you wish to play with "Disc menu's" i find that vlc will become unresponsive.
6) i guess its a limitation in VLC itself not being able to handle disc menus.
Yethidran
Post by Yethidran » Tue Feb 11, 2025 9:33 am
but my trusted and go to software player for uhd and bluray movies is and always will be "MPC-HC" over VLC.
mas1701
Post by mas1701 » Thu Feb 13, 2025 2:42 pm
Blu-ray error:
You need to install a valid Java Runtime Environment (JRE), so VLC can use it to run the Java menu program code. Most, but not all menus on Blu-ray use Java.
Playing from disc or from a harddisk rip makes no difference regarding menus. So AACS isn't relevant here either. VLC handles BD and UHD-BD the same - if menus work on BD, they will also work on BD-UHD. There isn't much structural difference between them.
Note 1: If your VLC is 64bit, Java must also be 64bit. If your VLC is 32bit, Java must also be available as a 32bit version on your system.
Note 2: Not every Java version works well with Blu-ray. In fact, only a few select versions do. If your player crashes often, you have the wrong version. It takes some effort to find one that works well. For me, I'm on Java 12.0.2 on Linux Mint 21.3.
>>> You may need a (free) Oracle user account to get a specific, older version of Java. <<<
sierrasawdust
Post by sierrasawdust » Fri Feb 21, 2025 12:05 am
That Java version info was super helpful, thank you!!!
