Destruction pictures of my Verbatim 43888 (Pioneer UD04)
Yethidran
Re: Destruction pictures of my Verbatim 43888 (Pioneer UD04)
And so far there is no "Conflicts with using MakeMKV Software" using this cheap but good casing.
Yethidran
wish i could post the side by side picture of this external casing and the verbatim casing, but i must respect the moderators here in makemkv as there is only a limited amount of bandwidth to be used in the forum. pictures do take up alot of space regarding bandwidth.
but trust me, this casing is nice and very usable.
imgur and imbed it with the image insertYethidran wrote: Tue Feb 11, 2025 8:37 am wish i could post the side by side picture of this external casing and the verbatim casing, but i must respect the moderators here in makemkv as there is only a limited amount of bandwidth to be used in the forum. pictures do take up alot of space regarding bandwidth.
must be direct to photo only right click open image and new tab and use that URL
Yethidran
razer
@Yethidran, do you have any tips on opening this Verbatim case?
Thanks in advance.
Thanks in advance.
Yethidran
sadly no tips at all on how to open up this casing, other than forcibly destroying the casing. i actually found in "Reddit" that one person posted pictures of this casing and saying that there are 2 small holes at each side of the casing to pry it open. i tried that, but no success at all. so i just forcibly broke open the casing. sorry buddy.
DavoBR
Yethidran
yes, thats the correct link. i pushed, pulled, poked, but no success.
razer
Thanks for the link. I'll try my luck and see how far I want to go before smashing this on the floor in frustration!
Just be careful. I'm sure there some snaps and it it possible to disassemle without breaking th enclosure.razer wrote: Fri Mar 14, 2025 9:27 pm Thanks for the link. I'll try my luck and see how far I want to go before smashing this on the floor in frustration!
razer
Mission accomplished. I was able to disassemble the case without too much damage.
Removed the LG drive, and dropped in a Pioneer drive.
Thanks for making this so difficult Pioneer.
Yethidran
thats cool buddy!!
you managed to pry open the casing without any visible damage.
but i guess it took alot of calm and patience on your side.
anyway, congratulation's.
cheers.
cheers.
