redmarple
Post by redmarple »
zittrig wrote: Mon Feb 10, 2025 9:58 pm 3.10MK (with sleep bug) or WH16NS60 1.02MK (without sleep bug).
Thank you. But why should I upgrade. Do I gain anything? Drive copies 4k discs.
zittrig
Post by zittrig »
I've learned that the 3.10MK or the WH16NS60 1.02MK rips faster if the disc are clean or has minimal surface issues like scratches e.g.. But there could be problems mit some 3-layer discs.
For "problem discs" the ASUS 3.02 or the LG BH16NS60 1.02 can be used 'cause they read longer with slow speed to get the datas.
But test it and decide by yourself. :)
redmarple
Post by redmarple »
zittrig wrote: Mon Feb 10, 2025 10:22 pm I've learned that the 3.10MK or the WH16NS60 1.02MK rips faster if the disc are clean or has minimal surface issues like scratches e.g.. Also could there be problems mit some 3-layer discs.
I cannot make mistakes when flashing the correct firmware?
The firmware pack has only 3.03 and 3.10 and I have 3.01 which I can backup to disk. Where can I get 3.02?
BH16NS60 has 1.02 and 1.01 and 1.03 in the pack.
zittrig
Post by zittrig »
Another support you can find right here in this topic in the first post.
Look for recommended firmware title and sleep bug. And there can be found two firmware packs. The all you need firmware pack and the MK firmware pack. The second contains some more older firmware versions also.
redmarple wrote: Mon Feb 10, 2025 10:39 pm
I think my firmware pack has the BW-16D1HT 3.02 firmware in it. Go to the SDFtool Flasher thread, first post.
csdesigns
Post by csdesigns »
Billycar11 wrote: Mon May 27, 2019 5:20 am This Guide Is Made By: Billy/Billycar11, MartyMcNuts, Blackened2687, Coopervid, d00zah, mike admin, SamuriHL, st4evr, TeddyRaspin, Woodstock, Bluntman, Alex/jonghotti, garygomm
Even if they didn't contribute directly i have used their information
Huge props and thanks goes out to everyone involved to make this possible. Just wanted to report my recent success with the BU40N I purchased last week. Drive arrived with the following fw:
Product: BD-RE BU40N
Revision: FR07
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.FRO7J
I was able to easily update to the 1.03 fw following Billycar11's detailed guide:
Manufacturer:
HL-DT-ST
Revision: 1.03
Highest AACS version: 77
Firmware version: 1.03
FYI, I installed the drive into my trusty old Sonnet Echo 15+ Thunderbolt 2 dock connected to a Mac Pro 6,1 (running Monterey 12.7.6) and flashed from there. Some slight modifications were performed to properly fit the drive into this enclosure since the BU40N is considerably slimmer than the previous existing drive (HL-DT-ST CT30F). Basically, just some 3M double-sided tape and rubber spacer rings were required to ensure the drive is balanced, as only one screw mount point aligned from the original included cage.
Echo 15 TB2:
  Vendor Name:	Sonnet Technologies, Inc.
  Device Name:	Echo 15 TB2
  Mode:	Thunderbolt 2
  Device ID:	0xC
  Vendor ID:	0x8
  Device Revision:	0x1
  Route String:	3
  Firmware Version:	25.2
  Port (Upstream):
  Status:	Device connected
  Link Status:	0x2
  Speed:	Up to 20 Gb/s x1
  Current Link Width:	0x2
  Cable Firmware Version:	0.1.23
  Link Controller Firmware Version:	0.14.0
  Port:
  Status:	No device connected
  Link Status:	0x7
  Current Link Width:	0x1
HL-DT-ST BD-RE BU40N:
  Firmware Revision:	1.03
  Interconnect:	USB
  Burn Support:	Yes (Generic Drive Support)
  Profile Path:	None
  Cache:	4064 KB
  Reads DVD:	Yes
  CD-Write:	-R, -RW
  DVD-Write:	-R, -R DL, -RAM, -RW, +R, +R DL, +RW
  BD-Write:	-R, -RE
  Write Strategies:	CD-TAO, CD-SAO, CD-Raw, DVD-DAO
  Media:	To show the available burn speeds, insert a disc and choose File > Refresh Information
Ripped 4x UHD BDs last night, with max speeds writing to internal dual-SSD RAID0 of the dock at 6x speed.
jjmkv
Post by jjmkv »
spamtom wrote: Thu Feb 06, 2025 12:40 am
Mr_Orange wrote: Wed Feb 05, 2025 12:31 pm
spamtom wrote: Wed Feb 05, 2025 12:23 pm Slightly nervous about having an app making and pulling files from a Russian server as obv there is a reputation associated with servers hosted in certain country’s which is why I went with pulling a public keydb file myself manually and vetting the file. Would prefer to do that each time. I followed a guide on here on how to add the keydb file I assume that’s still supported option. Any ideas on how you submit to the public keydb file? Cheers
We have all been using MakeMKV's SDF file for years without any issues, no matter where it has been hosted. Do you really think the software would be so widely used if it was routinely infecting people's computers?
Each to their own though. Grab the dump file that MakeMKV creates, send it to the relevant MakeMKV email address and create a post with the details of the film and the dump file. You can also attach the dump file to the post and one of the folks who help maintain the public KeyDB will grab it and add the key.
It's great that MakeMKV and its SDF download has been reliable for many years. However, relying solely on past experience or wide availability are not foolproof cybersecurity strategies (In fact the greater install base the more attractive it is to bad actors). Threats, such as supply chain attacks, are becoming more common and sophisticated, posing risks to even well-regarded software. Unfortunately, servers and communications originating from certain regions can also present higher risks of these attacks.
Perhaps my background in secops has heightened my awareness of these risks, but it doesn't hurt to stay vigilant and proactive in protecting yourself. A good example is Notepad++, where the update process was hijacked to distribute malicious installers of the StrongPity malware. Similarly, there are numerous documented cases of supply chain attacks in GitHub repositories. The Notepad++ and most of the GitHub supply chain attacks didn't involve the creators or maintainers of the software, so trusting them and their past work would have provided false reassurance in those cases.
For my own use, I prefer the zero trust strategy, anything that’s been downloaded from the internet gets throughly vetted first before using them, no auto updates etc. If others prefer automatic updates and are comfortable doing that, that's their choice. However, I don't mind the small inconvenience of manually obtaining files from time to time and doing my own checks—after all, better safe than sorry.
I appreciate your advice on sending the dump to the email. Cheers!
Beyond the scope of this particular thread, but definitely something that warrants discussion imo. Having to download anything from russia, regardless of how long it has worked without issue, seems like an odd choice. Whats the reasoning behind that? Is it just a matter of those keydbs needing to be hosted somewhere like that legally?
trooperdadon87
Post by trooperdadon87 »
trooperdadon87 wrote: Sun Feb 09, 2025 3:56 pm
d00zah wrote: Sun Feb 09, 2025 3:47 pm
trooperdadon87 wrote: Sun Feb 09, 2025 3:41 pm
like this?
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
now it says : Input file not found -- C:\Users\marcm\Downloads\The
Internal error 0x83000001
Use ' ' or " " around paths/filenames which include spaces.
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i 'C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin'
THANKS ! i think it was working.
Reading input file C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_211711301218_KZBIASC0500
100% Operation finished
Done successfully
what else do i have to do? fixing some bugs next (sleeping bug) or everything working now?
when i check now and open makemkv there is still 1.02 , why?
can someone help me? was it working or still 1.02 ? i dont know why there shows still 1.02 when i open makemkv ?
here is the information:
Firmware version: 1.02
Post by d00zah »
trooperdadon87 wrote: Sat Feb 15, 2025 4:14 pm ...
Try the SDFtool Flasher & the same FW ( HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin ).
mm13579
Post by mm13579 »
I have this setup and could not get it to read any disc. It said loading then said no disc in drive. I updated firmware as seen in attachment. It now does Blu ray, but it still won't find a UHD disc and I tried several and rebooted the PC?
Also this used to work after I flashed the firmware on this same PC to 1.03 about 1 year ago. But tried this week and had to flash it again to the one displayed to get it to register any disc. Also I did clean both the disc lasers with a alcohol wipe as that was also stated to try.
Any ideas
mm13579 wrote: Sat Feb 15, 2025 7:15 pm I have this setup and could not get it to read any disc. It said loading then said no disc in drive. I updated firmware as seen in attachment. It now does Blu ray, but it still won't find a UHD disc and I tried several and rebooted the PC?
Any ideas
Did yuo clean the UHD discs themselves? This is usually the first thing to do.
mm13579
Post by mm13579 »
I have cleaned them yes but I also have about 5 brand new UHDs I've tried and they are scratch free and cleaned with a cloth and there is nothing present on them?
Any other options, I even tried one in the past that worked with this UHD drive and now it doesn't about 1 year later?
It really doesn't make any sense to me
Any ideas
What firmware was on it before?
What actual drive model is it?
mm13579
Post by mm13579 »
HL-DT-ST BD-RE BU4040N
It had the 1.03 Firmware and worked for everything
mm13579 wrote: Sun Feb 16, 2025 2:39 am HL-DT-ST BD-RE BU4040N
So why would you flash it again with the same firmware? Doesn't make any sense...
