Thank you. But why should I upgrade. Do I gain anything? Drive copies 4k discs.zittrig wrote: Mon Feb 10, 2025 9:58 pm 3.10MK (with sleep bug) or WH16NS60 1.02MK (without sleep bug).
I've learned that the 3.10MK or the WH16NS60 1.02MK rips faster if the disc are clean or has minimal surface issues like scratches e.g.. But there could be problems mit some 3-layer discs.
For "problem discs" the ASUS 3.02 or the LG BH16NS60 1.02 can be used 'cause they read longer with slow speed to get the datas.
But test it and decide by yourself.
I cannot make mistakes when flashing the correct firmware?zittrig wrote: Mon Feb 10, 2025 10:22 pm I've learned that the 3.10MK or the WH16NS60 1.02MK rips faster if the disc are clean or has minimal surface issues like scratches e.g.. Also could there be problems mit some 3-layer discs.
But test it and decide by yourself.![]()
The firmware pack has only 3.03 and 3.10 and I have 3.01 which I can backup to disk. Where can I get 3.02?
BH16NS60 has 1.02 and 1.01 and 1.03 in the pack.
Another support you can find right here in this topic in the first post.
Look for recommended firmware title and sleep bug. And there can be found two firmware packs. The all you need firmware pack and the MK firmware pack. The second contains some more older firmware versions also.
I think my firmware pack has the BW-16D1HT 3.02 firmware in it. Go to the SDFtool Flasher thread, first post.redmarple wrote: Mon Feb 10, 2025 10:39 pmI cannot make mistakes when flashing the correct firmware?zittrig wrote: Mon Feb 10, 2025 10:22 pm I've learned that the 3.10MK or the WH16NS60 1.02MK rips faster if the disc are clean or has minimal surface issues like scratches e.g.. Also could there be problems mit some 3-layer discs.
Huge props and thanks goes out to everyone involved to make this possible. Just wanted to report my recent success with the BU40N I purchased last week. Drive arrived with the following fw:Billycar11 wrote: Mon May 27, 2019 5:20 am This Guide Is Made By: Billy/Billycar11, MartyMcNuts, Blackened2687, Coopervid, d00zah, mike admin, SamuriHL, st4evr, TeddyRaspin, Woodstock, Bluntman, Alex/jonghotti, garygomm
Even if they didn't contribute directly i have used their information
Product: BD-RE BU40N
Revision: FR07
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.FRO7J
Unrestricted read speed: Possible (with patched firmware)Code: Select all
Manufacturer:
HL-DT-ST
Revision: 1.03
Highest AACS version: 77
Firmware version: 1.03
Unrestricted read speed: YesCode: Select all
Echo 15 TB2:
Vendor Name: Sonnet Technologies, Inc.
Device Name: Echo 15 TB2
Mode: Thunderbolt 2
Device ID: 0xC
Vendor ID: 0x8
Device Revision: 0x1
Route String: 3
Firmware Version: 25.2
Port (Upstream):
Status: Device connected
Link Status: 0x2
Speed: Up to 20 Gb/s x1
Current Link Width: 0x2
Cable Firmware Version: 0.1.23
Link Controller Firmware Version: 0.14.0
Port:
Status: No device connected
Link Status: 0x7
Current Link Width: 0x1
Link Controller Firmware Version: 0.14.0Code: Select all
HL-DT-ST BD-RE BU40N:
Firmware Revision: 1.03
Interconnect: USB
Burn Support: Yes (Generic Drive Support)
Profile Path: None
Cache: 4064 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RAM, -RW, +R, +R DL, +RW
BD-Write: -R, -RE
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media: To show the available burn speeds, insert a disc and choose File > Refresh InformationRe: Ultimate UHD Drives Flashing Guide Updated 2025
Beyond the scope of this particular thread, but definitely something that warrants discussion imo. Having to download anything from russia, regardless of how long it has worked without issue, seems like an odd choice. Whats the reasoning behind that? Is it just a matter of those keydbs needing to be hosted somewhere like that legally?spamtom wrote: Thu Feb 06, 2025 12:40 amMr_Orange wrote: Wed Feb 05, 2025 12:31 pmWe have all been using MakeMKV's SDF file for years without any issues, no matter where it has been hosted. Do you really think the software would be so widely used if it was routinely infecting people's computers?spamtom wrote: Wed Feb 05, 2025 12:23 pm Slightly nervous about having an app making and pulling files from a Russian server as obv there is a reputation associated with servers hosted in certain country’s which is why I went with pulling a public keydb file myself manually and vetting the file. Would prefer to do that each time. I followed a guide on here on how to add the keydb file I assume that’s still supported option. Any ideas on how you submit to the public keydb file? Cheers
Each to their own though. Grab the dump file that MakeMKV creates, send it to the relevant MakeMKV email address and create a post with the details of the film and the dump file. You can also attach the dump file to the post and one of the folks who help maintain the public KeyDB will grab it and add the key.
It's great that MakeMKV and its SDF download has been reliable for many years. However, relying solely on past experience or wide availability are not foolproof cybersecurity strategies (In fact the greater install base the more attractive it is to bad actors). Threats, such as supply chain attacks, are becoming more common and sophisticated, posing risks to even well-regarded software. Unfortunately, servers and communications originating from certain regions can also present higher risks of these attacks.
Perhaps my background in secops has heightened my awareness of these risks, but it doesn't hurt to stay vigilant and proactive in protecting yourself. A good example is Notepad++, where the update process was hijacked to distribute malicious installers of the StrongPity malware. Similarly, there are numerous documented cases of supply chain attacks in GitHub repositories. The Notepad++ and most of the GitHub supply chain attacks didn't involve the creators or maintainers of the software, so trusting them and their past work would have provided false reassurance in those cases.
For my own use, I prefer the zero trust strategy, anything that’s been downloaded from the internet gets throughly vetted first before using them, no auto updates etc. If others prefer automatic updates and are comfortable doing that, that's their choice. However, I don't mind the small inconvenience of manually obtaining files from time to time and doing my own checks—after all, better safe than sorry.
I appreciate your advice on sending the dump to the email. Cheers!
trooperdadon87
can someone help me? was it working or still 1.02 ? i dont know why there shows still 1.02 when i open makemkv ?trooperdadon87 wrote: Sun Feb 09, 2025 3:56 pmTHANKS ! i think it was working.d00zah wrote: Sun Feb 09, 2025 3:47 pmUse ' ' or " " around paths/filenames which include spaces.trooperdadon87 wrote: Sun Feb 09, 2025 3:41 pm
like this?
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
now it says : Input file not found -- C:\Users\marcm\Downloads\The
Internal error 0x83000001
.\makemkvcon64.exe f --all-yes -d E: rawflash enc -i makemkvcon64.exe f --all-yes -d E: rawflash enc -i 'C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin'
Reading input file C:\Users\marcm\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_211711301218_KZBIASC0500
100% Operation finished
Done successfully
what else do i have to do? fixing some bugs next (sleeping bug) or everything working now?
when i check now and open makemkv there is still 1.02 , why?
here is the information:
Firmware version: 1.02
Try the SDFtool Flasher & the same FW ( HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin ).trooperdadon87 wrote: Sat Feb 15, 2025 4:14 pm ...
I have this setup and could not get it to read any disc. It said loading then said no disc in drive. I updated firmware as seen in attachment. It now does Blu ray, but it still won't find a UHD disc and I tried several and rebooted the PC?
Also this used to work after I flashed the firmware on this same PC to 1.03 about 1 year ago. But tried this week and had to flash it again to the one displayed to get it to register any disc. Also I did clean both the disc lasers with a alcohol wipe as that was also stated to try.
Any ideas
Any ideas
- Screenshot_20250215-122401~2.png (465.84 KiB) Viewed 13288 times
Did yuo clean the UHD discs themselves? This is usually the first thing to do.mm13579 wrote: Sat Feb 15, 2025 7:15 pm I have this setup and could not get it to read any disc. It said loading then said no disc in drive. I updated firmware as seen in attachment. It now does Blu ray, but it still won't find a UHD disc and I tried several and rebooted the PC?
Any ideas
I have cleaned them yes but I also have about 5 brand new UHDs I've tried and they are scratch free and cleaned with a cloth and there is nothing present on them?
Any other options, I even tried one in the past that worked with this UHD drive and now it doesn't about 1 year later?
It really doesn't make any sense to me
What firmware was on it before?mm13579 wrote: Sat Feb 15, 2025 7:15 pm I have this setup and could not get it to read any disc. It said loading then said no disc in drive. I updated firmware as seen in attachment. It now does Blu ray, but it still won't find a UHD disc and I tried several and rebooted the PC?
Any ideas
What actual drive model is it?
HL-DT-ST BD-RE BU4040N
It had the 1.03 Firmware and worked for everything
So why would you flash it again with the same firmware? Doesn't make any sense...mm13579 wrote: Sun Feb 16, 2025 2:39 am HL-DT-ST BD-RE BU4040N
