SDFFlasher is just a GUI and needs Makemkv to be installed.corefunctions wrote: Fri Jan 17, 2025 6:24 pmI have MakeMKV set up on my Mac but it's not able to open SDFTool so I used my friends PC to try and upload the software, but he doesn't have MakeMKV downloaded. This is what I see and my Player is connected and being read by the laptop.MartyMcNuts wrote: Wed Jan 15, 2025 11:05 pmDo you have MakeMKV installed and in the default location?corefunctions wrote: Wed Jan 15, 2025 8:07 am I am trying to flash my LG BP60NB10 and when I have my SDFtool open and ready to choose drive and firmware, then drop down menu of drive will not display my drive. Anyone got any tips for this?
Please and thank you.
Re: SDFtool Flasher
Dunebuggydrew
Re: SDFtool Flasher
Let me send you some money, brother. You saved me from a big headache. Great tool
Re: SDFtool Flasher
Sure thing. My Paypal is MartyMcNuts@outlook.comDunebuggydrew wrote: Sun Jan 19, 2025 3:03 pm Let me send you some money, brother. You saved me from a big headache. Great tool
Re: SDFtool Flasher
Hello. I'm a bit of a noob when it comes to this stuff, but I have a HTPC (a nuk) hooked to a 4K TV, and I liked the idea of having a reflashed Blu Ray DVD drive hooked up to it to play UHD DVDs vs buy "yet another" DVD player. I found and followed this site for instructions on how to reflash an ASUS BR drive to play UHD content, but am having an issue that I have not seen replicated here -- apologies if it has, and I missed it.
I have a brand new ASUS BW-16D1HT drive that started its short life in a Vantec NST-536S3-BK enclosure. Once I realized that enclosure might not work for flashing (it may not have), I purchased Vantec DX3 NST-540S3-BK enclosure and put the drive in that.
I used the latest SDF tool 1.3.5
I used the "all you need" firmware pack, used the software for ASUS 3.10
Using both an ancient Win10 laptop and my NUC computer, I ran the flash tool as an administrator on drive in the unsupported enclosure:
- Got an error "command produced error code 0x86062900
- Repeated, got no errors
Drive (or computer specifically) will recognize UHD disk titles just as video shows. Both VLC player and MakeMPV says "missing keys, cannot continue" with UHD disks
Installed drive into the new (supported) enclosure, repeated steps, got the same error. This thread says "dont sweat the error code, it happens". Did this twice. Drive plays normal DVDs just fine.
What am I missing? Did I brick the thing? Apologies in advance!
Re: SDFtool Flasher
Show us your MakeMKV drive info / Libredrive info sections.wbread99 wrote: Tue Jan 28, 2025 4:11 pm Hello. I'm a bit of a noob when it comes to this stuff, but I have a HTPC (a nuk) hooked to a 4K TV, and I liked the idea of having a reflashed Blu Ray DVD drive hooked up to it to play UHD DVDs vs buy "yet another" DVD player. I found and followed this site for instructions on how to reflash an ASUS BR drive to play UHD content, but am having an issue that I have not seen replicated here -- apologies if it has, and I missed it.
Re: SDFtool Flasher
Sorry I was at work...MartyMcNuts wrote: Wed Jan 29, 2025 5:54 amShow us your MakeMKV drive info / Libredrive info sections.wbread99 wrote: Tue Jan 28, 2025 4:11 pm Hello. I'm a bit of a noob when it comes to this stuff, but I have a HTPC (a nuk) hooked to a 4K TV, and I liked the idea of having a reflashed Blu Ray DVD drive hooked up to it to play UHD DVDs vs buy "yet another" DVD player. I found and followed this site for instructions on how to reflash an ASUS BR drive to play UHD content, but am having an issue that I have not seen replicated here -- apologies if it has, and I missed it.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ...
Bus encryption flags: 1F
Highest AACS version: 72
Firmware version: 3.10
Disc Information
Data capacity: 62.8 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Re: SDFtool Flasher
Your drive looks fine.wbread99 wrote: Sun Feb 02, 2025 11:00 pmSorry I was at work...MartyMcNuts wrote: Wed Jan 29, 2025 5:54 amShow us your MakeMKV drive info / Libredrive info sections.wbread99 wrote: Tue Jan 28, 2025 4:11 pm Hello. I'm a bit of a noob when it comes to this stuff, but I have a HTPC (a nuk) hooked to a 4K TV, and I liked the idea of having a reflashed Blu Ray DVD drive hooked up to it to play UHD DVDs vs buy "yet another" DVD player. I found and followed this site for instructions on how to reflash an ASUS BR drive to play UHD content, but am having an issue that I have not seen replicated here -- apologies if it has, and I missed it.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ...
Disc Information
Number of layers: 2
MakeMKV needs internet access to download the hashed key database for UHD discs. When you try to rip a UHD disc, does the log window say anything about "HK download failed"??
Have you integrated VLC and other players into MakeMKV via preferences?
TechNikephoros
Re: SDFtool Flasher
I'm running into an issue trying to update the 4K drive I just bought. I've heard from others on here that they were able to update it, but I'm getting the following error: .
Has anyone seen this and know of a solution?
This is my drive info:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
at System.Int32.Parse(String s)
at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.5.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Assembly Version: 6.0.2.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.CompilerServices.Unsafe
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
OS device name: E:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW43
Serial number: 7MEQVHAKKH81KD
Firmware date: 2120-11-02 14:15
Highest AACS version: 81
Re: SDFtool Flasher
The string is incorrect because it has hp in it. This is the first time I have ever seen a HLDS drive have hp in front of it. I will see if I can update SDFtool flasher. Give me a few hours.TechNikephoros wrote: Mon Feb 10, 2025 5:35 pm I'm running into an issue trying to update the 4K drive I just bought. I've heard from others on here that they were able to update it, but I'm getting the following error: SDFlasher_Error.png.
Has anyone seen this and know of a solution?This is my drive info:Code: Select all
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.FormatException: Input string was not in a correct format. at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type) at System.Int32.Parse(String s) at SDFtool_Flasher_Updated.Form1.comboBox_DriveList_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m) at System.Windows.Forms.ComboBox.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** System.Private.CoreLib Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- SDFtool Flasher Assembly Version: 1.3.5.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Windows.Forms Assembly Version: 6.0.2.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Windows.Forms.Primitives Assembly Version: 6.0.2.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.InteropServices Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Drawing.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.Specialized Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Drawing.Common Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Threading Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Diagnostics.TraceSource Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Diagnostics.Process Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Microsoft.Win32.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel.EventBasedAsync Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Threading.Thread Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Accessibility Assembly Version: 4.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel.TypeConverter Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Numerics.Vectors Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Memory Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ComponentModel Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Resources.Extensions Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Drawing Assembly Version: 6.0.2.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.ObjectModel Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Linq Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.Serialization.Formatters Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.Concurrent Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- mscorlib Assembly Version: 4.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Microsoft.Win32.SystemEvents Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.NonGeneric Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Configuration.ConfigurationManager Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.InteropServices.RuntimeInformation Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Private.Uri Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Security.Cryptography.Algorithms Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Security.Cryptography.Primitives Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Xml.ReaderWriter Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Private.Xml Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Text.RegularExpressions Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Net.WebClient Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Text.Encoding.Extensions Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Xml.XmlSerializer Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- Microsoft.Win32.Registry Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.CompilerServices.Unsafe Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Runtime.Loader Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Diagnostics.StackTrace Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Reflection.Metadata Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- System.Collections.Immutable Assembly Version: 6.0.0.0 Win32 Version: n/a CodeBase: ---------------------------------------- ************** JIT Debugging **************Drive Information
OS device name: E:
Product: BDRE BU40N
Revision: BW43
If you are in a hurry, you can use the MakeMKV command line to get it done. It's not hard.
TechNikephoros
Re: SDFtool Flasher
I will wait for the newer version of SDFTool, thank you!!MartyMcNuts wrote: Mon Feb 10, 2025 8:33 pmThe string is incorrect because it has hp in it. This is the first time I have ever seen a HLDS drive have hp in front of it. I will see if I can update SDFtool flasher. Give me a few hours.TechNikephoros wrote: Mon Feb 10, 2025 5:35 pm I'm running into an issue trying to update the 4K drive I just bought. I've heard from others on here that they were able to update it, but I'm getting the following error: SDFlasher_Error.png.
OS device name: E:
Product: BDRE BU40N
Revision: BW43
TechNikephoros
Re: SDFtool Flasher
I'm attempting to find some documentation on using the MakeMKVcon command line in windows to rename the device. Has anyone done this before? I see the command for listing the drives, but not updating the drive names.MartyMcNuts wrote: Mon Feb 10, 2025 8:33 pmThe string is incorrect because it has hp in it. This is the first time I have ever seen a HLDS drive have hp in front of it. I will see if I can update SDFtool flasher. Give me a few hours.TechNikephoros wrote: Mon Feb 10, 2025 5:35 pm I'm running into an issue trying to update the 4K drive I just bought. I've heard from others on here that they were able to update it, but I'm getting the following error: SDFlasher_Error.png.
OS device name: E:
Product: BDRE BU40N
Revision: BW43
Re: SDFtool Flasher
Not possible.TechNikephoros wrote: Tue Feb 11, 2025 4:47 pmI'm attempting to find some documentation on using the MakeMKVcon command line in windows to rename the device. Has anyone done this before? I see the command for listing the drives, but not updating the drive names.MartyMcNuts wrote: Mon Feb 10, 2025 8:33 pmThe string is incorrect because it has hp in it. This is the first time I have ever seen a HLDS drive have hp in front of it. I will see if I can update SDFtool flasher. Give me a few hours.TechNikephoros wrote: Mon Feb 10, 2025 5:35 pm I'm running into an issue trying to update the 4K drive I just bought. I've heard from others on here that they were able to update it, but I'm getting the following error: SDFlasher_Error.png.
Did you try the updated SDFtool flasher I sent you?? It should work.
TechNikephoros
Re: SDFtool Flasher
The latest version works great, thank you!!
Re: SDFtool Flasher
Thanks for letting me know. Just to see after the flash, can you now show your MakeMKV drive/libredrive info sections?
Re: SDFtool Flasher
I have an LG Slim WP50NB40-NB50 that I decided to take the plunge and flash. I read several discussions with people with this same drive and went through the steps. I was able to use SDFlasher v1.3.5, and it said that it was successful. MakeMKV drive information also looks correct based on what I have seen others post:
However, the drive no longer opens or reads the disc (when manually forcing the drawer open). Is there a step I missed somehow?
OS device name: H:
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: ********************
Firmware date: 2114-09-03 17:32
Firmware version: 1.00
Unrestricted read speed: YesHowever, the drive no longer opens or reads the disc (when manually forcing the drawer open). Is there a step I missed somehow?
