Avengers Endgame Rip - No DolbyVision
tidbito
Post by tidbito » Sun Feb 09, 2025 6:55 pm
Greetings. Wondering what I'm doing wrong here. Have my Avengers Endgame UHD disc and trying to rip with DolbyVision. The disc rips fine but only getting HDR-- no DV.
MediaInfo doesn't see an DV info-- just HDR plus the atmos audio track:
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 3 h 1 min
Bit rate : 36.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.181
Stream size : 45.6 GiB (82%)
Writing library : ATEME Titan File 3.9.0 (4.9.0.0)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 777 kb/s
Maximum bit rate : 8 430 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 6.05 GiB (11%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 13
Bed channel count : 1 channel
Bed channel configuration : LFE
Product: BD-RE WH16NS40
Revision: 1.02
Serial number: M6KICEK0953
Firmware date: 2117-03-10 16:50
Highest AACS version: 76
Firmware version: 1.02
BD raw data read:
Drive flashes fine
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash enc -i C:\FW\HL-DT-ST-BD-RE_WH16NS40-NS50-1.0
5-NM00900-212005061440.bin
Reading input file C:\FW\HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.02_211703101650_M6KICEK0953
100% Operation finished
Done successfully
Thanks for any suggestions.
ryley
Re: Avengers Endgame Rip - No DolbyVision
Post by ryley » Sun Feb 09, 2025 11:34 pm
My understanding was 'Black Panther' was the only Marvel 4K disc to include Dolby Vision. Was there a particular reason you thought this disc would include DV? I know most of the MCU on Disney+ has Dolby Vision but that is not relevant for the physical releases.
tidbito
Post by tidbito » Mon Feb 10, 2025 12:17 am
The case/box has the DolbyVision and DolbyAtmos logos on it.
ryley
Post by ryley » Mon Feb 10, 2025 12:26 am
tidbito wrote: Mon Feb 10, 2025 12:17 am The case/box has the DolbyVision and DolbyAtmos logos on it.
That is interesting. Could you please provide a photo of the case and disc? I ask because I can't see anything on blu-ray.com about any release of the movie including Dolby Vision.
Edit: Are you sure the case doesn't mention 'Dolby Digital' and 'Dolby Atmos'?
tidbito
Post by tidbito » Mon Feb 10, 2025 12:27 am
SOaB
I just looked at the boxcover again. Damn my aging eyes. It def has the DolbyAtmos logo. It has another Dolby logo right next to it. I thought it was DolbyVision but looking closer it’s just DolbyDigital. … fml
Nevermind. Smh
ryley
Post by ryley » Mon Feb 10, 2025 12:35 am
tidbito wrote: Mon Feb 10, 2025 12:27 am SOaB
Nevermind. Smh
Thanks for following up. It is an easy mistake to make. I asked about Dolby Digital because someone on Reddit had a similar query with their copy of 'Avengers Endgame': Link
tidbito
Post by tidbito » Mon Feb 10, 2025 12:47 am
Appreciate the response. My eyes genuinely couldn’t see the “Digital” under the logo and I’d assumed it said Vision cuz it was next to the Atmos one and with it being a UHD box I just assumed.
Sucks getting old. Lol
